If anyone doesn't do this by tomorrow night I can post up any numbers out of the moog catalog that you need. One problem I have found working in the auto parts industry is that no matter what the box says sometimes you will run across reboxed parts from changeovers or simply from shady individuals who swap parts and return the cheap parts in the expensive part's box. That why I ordered all of my Moog front end parts and made sure to check each part to make sure it was really a moog part and not some no name rebox.
How do you know if it is reboxed or not? Does Moog put the P/N's on the parts? Also, Is moog better than Spicer? I would like the P/N's for Moog as well, for my '71 RR...THANX
