fuseble link? ar ethe fuseable links on / connected to the relay that is monted on the fenderwell?
yes just that one. Useally has a thick rubbery "tag" on it. See if you have power between the downstream side of it and the firewall bulkhead.
Is there a place that sells factory style repros of the fusible link with that tag on it? When mine went out, I just replaced it with a piece of fusible link I picked up in a roll from autozone. Would kind of like to have a factory style replacement to put in there.
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
