how do you replace the shift rod seal in a 904? do you just pop it out from the outside and tap the new seal in around the shift rod? should i clean the area with anything before installing new seal? also the converter seal, same question just pop it out and install new seal? The converter seal looks brand new and the rubber is soft ( should i replace it anyway)?
