Page 9 of 9 < 1 2 3 4 5 6 7 8 9
#2427116 - 01/01/18 12:00 PM Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Kevin I]
Wesd100 Offline
Loc: Texas,usa
Is there any way to get those pictures back on here?
#2427906 - 01/02/18 03:59 PM Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Kevin I]
Wesd100 Offline
Loc: Texas,usa
Has anyone tried these Drop Spindles from X2industries?
wondering about quality?
1978-1993 Dodge Ram, Charger, Trailduster 2" Drop Spindles
[DG7893DRM2]
Your Price: $373.95
www.x2industries.com
1-800-823-0320
instructions:
-NEED TO USE 84 ROTORS(PART #5315) TO MAINTAIN 5450 BOLT PATTERN
-FLIP TIE RODS
-REQUIRES LARGER INNER BEARING ON 83 AND DOWN CODE11
-REVERSE TAP OF Ball Joint FOR MORE CLEARANCE
#2428526 - 01/03/18 07:11 PM Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Wesd100]
68dodge Offline
Loc: ,Pa.
you may know this already, if you only want a 2" drop, use the van lower control arms or just cut some off the coil spring. A little easier than having to change lot more. I went to a 4" drop. Had to get some custom made upper control arms and they still needed modified to work. Had to do some welding to mount them, plus buy more parts for them to work.
#2428804 - 01/04/18 09:32 AM Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Kevin I]
Eggman Offline
Loc: Georgetown de usa
I just installed a set of rear lowering shackles from x2 two weeks ago. Good quality stuff.
25,348 Registered Members
190,243 Topics
What now for this b1 exhaust port
by kevinlc
35 minutes 48 seconds ago
engine id from bottom of engine up on a lift
by orange elephants
39 minutes 34 seconds ago
Which Scirocco Style Radiator??
by Blucuda413
40 minutes 17 seconds ago
Near tragedy in Kentucky today.
by Challenger 1
Today at 07:36 PM
