Re: Holley Street Dominator intake for 318 info?
[Re: dogdays]
#2276069
03/25/17 05:05 PM
03/25/17 05:05 PM
Posts: 274 Granbury TX
Prochargedmopar
Granbury TX
I guess that means I won't be re-drilling the Edel LD4B to fit on the magnum heads if it will be worth something in stock form later on down the road.
Being they both have the small 318 exit port size as I just took a peak at em'
I may go with the single plane with 2" carb spacer. I can let my son use the LD4B on his 318.
To start I will be putting the P600B back on the 360. 12psi pulley.
It will have some different internals that I have acquired since the last time it ran. Blower cam, dished pistons, Total seal rings, main studs, and home ported magnum heads.
Then later going to a 78/75 turbo or most likely dump it into my son's car and go 451 stroker and 80mm turbo.
"Old" member Registered: Sep 2001 Lost my credentials, I'm Back!! LOL 71 Ply Satellite Procharged 73 Dodge Dart Swinger 73 Ford F-100 390/Sniper efi/back to carb 01 Town and Country Limited 08 Dodge 2500 6.7 5" Deleted 02 Mercedes C230K 19 Camry
[Re: Prochargedmopar]
#2276703
03/26/17 07:44 PM
03/26/17 07:44 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Had my LD4B on Magnum style heads. They were Engine Quest and they were tapped for LA intake manifold. I loved that intake but had to take it out when it would not clear the Sanden A/C compressor. The upper radiator hose/thermostat was in the way. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: LXguy]
#2498459
05/21/18 12:26 AM
05/21/18 12:26 AM
Prochargedmopar
Granbury TX
I ended up buying a Victory 340 new off ebay.
I will let my Son use the LD4B as we finally got all the parts here for his 318.
I also acquired a complete, less A/C compressor 2000 5.9 magnum engine. I'm pondering using the Holley street dominator on it converted to EFI.
I saw that the stock keg intake only flows 180cfm max. I still wonder how much this single plane holley unit will flow.....?!?!?!
