Re: easiest way to swap an EFI Magnum into E body? [Re: fstfish66] #626715
07/22/10 11:26 AM
07/22/10 11:26 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
better performance so far ( dyno test) i have yet to get to the track
better mileage too!
Re: easiest way to swap an EFI Magnum into E body? [Re: DJVCuda] #626716
07/22/10 11:29 AM
07/22/10 11:29 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
better mileage too!
might be worht it if i could sell my carbs for half of whats in them,,,,so your total ?? im guessing 2500??
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: easiest way to swap an EFI Magnum into E body? [Re: fstfish66] #626717
07/22/10 11:30 AM
07/22/10 11:30 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
i though you would consider it for the street rod... it's a setup designed for them.... not he blower car.
got a tank from rockvalley, they put in an EFI pump in there.
Re: easiest way to swap an EFI Magnum into E body? [Re: DJVCuda] #626718
07/22/10 11:46 AM
07/22/10 11:46 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
i may consider it for the rod,,if the pricing was afforable,,just got off the phone with mega squirt,,making the factory magnum efi work it too costly,,, so i may just rebuild a 318 i have here,,,been thinking if i find a set of 360 type heads, have pistons made to be at 9.5 compression with the bigger valve heads,,bigger chambers and a stock 340 cam,,may be the ticket to having and affordable dependable motor,,,
2015 cherokee
2013 R/T classic
Re: easiest way to swap an EFI Magnum into E body? [Re: fstfish66] #626719
07/22/10 11:59 AM
07/22/10 11:59 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Depending on the price of the Magnum engine you're looking at, throwing a carb and intake on that engine may be a simpler/cheaper/faster alternative to rebuilding an on-hand engine. You could sell some of the EFI stuff, too.
The Magnum engines have LOTS of benefits that may entice you - better heads for swirl and quench, roller cam, thinner piston rings for less friction, etc. More hp and better MPG do come hand-in-hand with a 5.2/5.9 Magnum (versus an LA).
Re: easiest way to swap an EFI Magnum into E body? [Re: Fury Fan] #626720
07/22/10 12:05 PM
07/22/10 12:05 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
yes im considering making an offer on the motor ,,and searching a carb intake,,dual plane ??? to have all the other bennys of the magnum,,,roller cam,,serpintine belt etc,,seems the easiet way to run the factory efi is a hot wire conversion ,,,searching the intake now
2015 cherokee
2013 R/T classic
Re: easiest way to swap an EFI Magnum into E body? [Re: fstfish66] #626721
07/22/10 12:31 PM
07/22/10 12:31 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Re: easiest way to swap an EFI Magnum into E body? [Re: Fury Fan] #626722
07/23/10 01:14 AM
07/23/10 01:14 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
Here are some links I saved a while ago. summit changed something on their website a while back so some of these might not work right.
http://store.summitracing.com/egnsearch....+115+4294888794
http://www.summitracing.com/search/?keyword=dcc-5007790&dds=1
http://www.professional-products.com/manifoldsProductmopar.php
http://www.summitracing.com/parts/PFS-55026/
ok thanks ill take a look
2015 cherokee
2013 R/T classic
Re: easiest way to swap an EFI Magnum into E body? [Re: Fury Fan] #626723
07/23/10 01:21 AM
07/23/10 01:21 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
thanks for the links,, i had seen the edddy and mopar but the p p didnt come up in the jegs/summit search,,thanks a gain
2015 cherokee
2013 R/T classic
Re: easiest way to swap an EFI Magnum into E body? [Re: fstfish66] #626724
07/28/10 12:19 AM
07/28/10 12:19 AM
Monroe, LA USA
Carsavior Offline
Carsavior  Offline
Monroe, LA USA
Bump up for James
Re: easiest way to swap an EFI Magnum into E body? [Re: Fury Fan] #626725
07/28/10 07:26 AM
07/28/10 07:26 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Has anyone ever seen a Magnum V8
controlled by a
MoTec
or
Haltech
aftermarket EFI computer?
Re: easiest way to swap an EFI Magnum into E body? [Re: 360view] #626726
07/28/10 08:07 AM
07/28/10 08:07 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
controlled by a
MoTec
or
Haltech
only after market computer ive seen on a magnum is a mega squirt kit
2015 cherokee
2013 R/T classic
Re: easiest way to swap an EFI Magnum into E body? [Re: fstfish66] #626727
07/28/10 10:24 AM
07/28/10 10:24 AM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
If it has all the right hook ups and signals/sensors, don't see why you couldn't do it. My fall back plan for my van if I can't get a Megasquirt to work satisfactorilly is to put on a Hydra Nemesis EMS, as my brother is a dealer for those and very familiar with tuning them.
Re: easiest way to swap an EFI Magnum into E body? [Re: Alikazam] #626728
07/30/10 05:15 PM
07/30/10 05:15 PM
Monroe, LA USA
Carsavior Offline
Carsavior  Offline
Monroe, LA USA
btt
Re: easiest way to swap an EFI Magnum into E body? [Re: wldtm] #2469323
03/20/18 07:30 PM
03/20/18 07:30 PM
OH
2
2010Charlie Offline
2010Charlie  Offline
OH
I would like to get a hold of you about your harnesses tried to PM you but it said it was full.
Re: easiest way to swap an EFI Magnum into E body? [Re: 2010Charlie] #2470825
03/23/18 04:15 AM
03/23/18 04:15 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Not sure what his status is - that post is 8 years old, and looking at his profile, that member hasn't posted in here in 3 years.
BTW, welcome to Moparts . . .
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: easiest way to swap an EFI Magnum into E body? [Re: Evil Spirit] #2470960
03/23/18 02:32 PM
03/23/18 02:32 PM
dogdays Offline
dogdays  Offline
First of all any 318 or 360 TBI engine is not a Mag engine. Period. The 5.2 Magnum engines showed up in 1992, the 5.9 Mag engines a couple of years later.
Enginequest heads can be had with either LA or Mag intake faces.
The OP's question was to swap an "EFI Magnum". That seems to indicate the preference for fuel injection, so suggesting a carb is not answering the question.
I seem to remember that none of the Mag engines had advance built into the distributor. It's all done in the ECM.
The more complete package you swap into the older car, the better. The easiest way to do that is keep the computer and wiring harness with the engine, as I see it.
R.
