Page 4 of 4 1 2 3 4
Re: Anyone using Rotella Diesel oil in their musclecars? [Re: pinkduster] #2392274
10/24/17 12:11 PM
10/24/17 12:11 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i think i see zinc is almost 1200ppm...
Re: Anyone using Rotella Diesel oil in their musclecars? [Re: pinkduster] #2392280
10/24/17 12:18 PM
10/24/17 12:18 PM
Stevensville, ON
Frank Raso Offline
Frank Raso  Offline
Stevensville, ON
I see that the phosphorus (antiwear component of ZDDP) level was only 825 ppm in your sample of Delo 15W-40 and that it had the low end of viscosity (12.6 cSt @ 100°C). The viscosity range for 40-grade oils is 12.5 to <16.3 cSt.
Re: Anyone using Rotella Diesel oil in their musclecars? [Re: dogdays] #2392322
10/24/17 01:46 PM
10/24/17 01:46 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Originally Posted By dogdays
To the resurrectionist: If you want to ask a question don't you think you could just make a new post? Are the Mods charging for starting a thread? Some newby is going to read the old stuff and "learn" a crapload of incorrect information.
Rotella? Go to your local Walmart and look at the Diesel oil selection. There are now THREE grades of Rotella. Saying put Rotella in it has little meaning unless you specify the grade.
R.
Who is the newby here? I guess you're referring to me? Why so critical and picky for crying out loud. If so I joined six years ago. I was asking about VR1 since it was mentioned in thread and thread had died. Thought it was ok and didn't start a new one because so often there are multiple threads covering related information. No, they don't charge for new threads, but man there are a lot of redundant threads. Sorry if I offended....again. I more laid back than the average member here, so it appears.
Facts are stubborn things.
Re: Anyone using Rotella Diesel oil in their musclecars? [Re: Frank Raso] #2393175
10/26/17 12:49 AM
10/26/17 12:49 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
That was what was in it when I bought it. It has been switched back to Rotella T4 15/40.
The last analysis report for T4 I saw on Bob is the Oilguy showed similar Zinc levels and Phos around 900-1000 ppm IIRC. I don't recall the viscosity but there were no negative comments on it so I assume it is acceptable.
Kevin
Re: Anyone using Rotella Diesel oil in their musclecars? [Re: pinkduster] #2393407
10/26/17 04:02 PM
10/26/17 04:02 PM
Stevensville, ON
Frank Raso Offline
Frank Raso  Offline
Stevensville, ON
HAMB member Blues4U states that he is a lubrication engineer and his posts confirm that he is quite knowledgeable about engine oils.
One of the points he makes is that modern HDEO is very suitable for flat-tappet gasoline engines and that these oils do not require ZDDP supplements. This is in agreement with GM TechLink's Engine Oil Myths.
The Delo and Rotella appear to be excellent flat-tappet engine lubricants even with the much lower phosphorus concentrations than the 1400+ ppm that many people believe are crucial. I also think that it is not beneficial to use an oil that is thicker than necessary. See Engine Wear.
Re: Anyone using Rotella Diesel oil in their musclecars? [Re: pinkduster] #2393548
10/26/17 10:16 PM
10/26/17 10:16 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Good info.
Re: Anyone using Rotella Diesel oil in their musclecars? [Re: pinkduster] #2394902
10/29/17 04:01 PM
10/29/17 04:01 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
me and my sons use it primarily in older engines the viscosity is good and so is the price im currently running it in my 500 strocker with no problems
Re: Anyone using Rotella Diesel oil in their musclecars? [Re: pinkduster] #2395262
10/30/17 11:07 AM
10/30/17 11:07 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
This is the answer I got from Shell, when I asked about the new formulation. I use it in my older muscle car engines, and recommend it to my customers engines.
Hi Jim,
Our CK-4 formulation still has about 1200 ppm of zinc and 1100 ppm of phosphorus, and should still be able to provide adequate protection for flat tappet engines. I’ve attached a brochure that goes over the chemical changes in detail.
I hope this helps.
Best regards,
Aly
Shell Technical Information
1-800-237-8645 (Option 3, 1)
Safety and technical data sheets for active Shell products can be found at www.epc.shell.com.
Page 4 of 4 1 2 3 4
