Re: Show me a 500hp "default" stock stroke 340/360 recipie
[Re: Streetwize]
#2526423
07/24/18 02:37 PM
07/24/18 02:37 PM
Posts: 11,708 Portage,michigan
B3422W5
Portage,michigan
I have a 260@ 50 solid( on a 106) in at 102 in my car and it idles happily at 1100 rpm like a Packard. Stock stroke 360
[Re: Streetwize]
#2526472
07/24/18 04:23 PM
07/24/18 04:23 PM
Posts: 192 Gravataí, RS, Brazil
360tripleblack77
I'm running with a 360 engine that made 464WHP using Super Victor Intake and Mighty Demon 750. So I've changed to Tunnel Ram and two Mighty Demons 750. I didn't run on dyno after that but the time on the track drop from 6.98 to 6.73. You can see the setup at this video: https://www.youtube.com/watch?v=ap8u2OfaBCw
'77 Brazilian Dodge Charger R/T - Street Car Footbrake, Pump Gas, SB Mopar 360" N/A 3300lbs, Leaf Spring + Assassin Bars Best 1/8 mile ET 1.50 60' / 4.31 330' / 6.73@102.54mph
[Re: 360tripleblack77]
#2526475
07/24/18 04:28 PM
07/24/18 04:28 PM
Posts: 20,158 PA.
pittsburghracer
The super Victor Intake sucks until you do major porting on one
#2526744
07/25/18 05:34 AM
07/25/18 05:34 AM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
I'm running with a 360 engine that made 464WHP using Super Victor Intake and Mighty Demon 750. So I've changed to Tunnel Ram and two Mighty Demons 750. I didn't run on dyno after that but the time on the track drop from 6.98 to 6.73. You can see the setup at this video: https://www.youtube.com/watch?v=ap8u2OfaBCw WOW. Sounds great! Ya see...that idle. Looks like it was @ 1100? I could live with that for a driver. imagine seein' that thing pull up at a stop light. the joy.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: pittsburghracer]
#2526758
07/25/18 08:58 AM
07/25/18 08:58 AM
360tripleblack77
I agree John! On my SV I did a deep port match and a basic plenum rework. I did the same work on tunnel ram. Measuring Weiand Tunnel Ram I can see that it has a lot of little points where I could work, starting by port match and going through runner until the plenum...
[Re: Skeptic]
#2526761
07/25/18 09:12 AM
07/25/18 09:12 AM
360tripleblack77
It's a Solid Flat Tappet Custom Comp Cams 256/260@.050, 108 Lobe Center and .580/.600 lift in.
[Re: mopardude318]
#2526765
07/25/18 09:19 AM
07/25/18 09:19 AM
360tripleblack77
You're right! Idle is 1100 RPM and believe me, that's amazing to ride on the street. Maybe in a 408" you can drop the idle around 1000 RPM easily...
#2526770
07/25/18 10:02 AM
07/25/18 10:02 AM
Posts: 20,158 PA.
pittsburghracer
I still have my super Victor Intake and did end up going 9.74 with it on my 408 but with two ported Indy intakes on the shelf not sure if I would ever try it again or not. Finally had a chance to watch your video last night and the car sounds great. Looks like a fun ride. Go out and have some fun
#2527285
07/26/18 11:20 AM
07/26/18 11:20 AM
360tripleblack77
Thank you John! my goal for this year is run at 6.50s. Next race will be in september... Let's do it!!!
[Re: moparx]
#2528228
07/28/18 11:43 AM
07/28/18 11:43 AM
Posts: 1,051 The Great White North
RAMM
500hp stock stroke 360 500 hp 360 with w2's These are two of many examples I have built as I am not a huge fan of the 4" stroke stuff. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
#2551546
09/18/18 03:17 PM
09/18/18 03:17 PM
B3422W5
Portage,michigan
You're right! Idle is 1100 RPM and believe me, that's amazing to ride on the street. Maybe in a 408" you can drop the idle around 1000 RPM easily... I am a big believer in having a high idle with a flat tappet cam. Have a 1 wire alternator that charges from 1500 rpm on up. So at the track i keep it at 1500 so its always charging
