67 Coronet, Rear Springs, Sway Bars and Shocks.
#2625225
02/23/19 09:12 PM
02/23/19 09:12 PM
Posts: 2 Florida
Poppinsmoke
Gentlemen,
I am in the process of trying to upgrade my 67 Coronet from Street/Strip to a weekend fun toy that can go around a corner or two without dragging the door handles.
So far swapped the big block for an aluminum headed 408 small block, bought 1.03 torsion bars, adjustable strut rods, 16 to 1 manual steering box.
The car already had an 11-inch power disc brake kit on it.
So now my focus is on Wheels and Tires, Rear Springs, Sway Bars, and Shocks.
I like the look of the 17 inch VN501, but I see that there are better tire choices in an 18 wheel aesthetically I like a little less wheel and little more sidewall.
Was thinking a 265 on 17x8 with 4.5bs all the way around if I can fit it.
1 and 3/8 Front sway bar and a 1 inch rear.
Shocks are rear springs I am little a little fuzzier on, I have never set a car up to do anything other than going fast in a straight line.
Only "road racing" was with Crown Vics and Chargers as part of my job.
Any advice or reference material would be greatly appreciated even if it is to tell me I am on the wrong track (no pun intended)
Not looking for a 9/10 track car, but a weekend fun machine.
Thank you in advance for any replies.
Re: 67 Coronet, Rear Springs, Sway Bars and Shocks.
[Re: Skeptic]
#2625325
02/24/19 03:59 AM
02/24/19 03:59 AM
Posts: 1,491 Lethbridge, AB, Canada
dangina
Buy Andy Fs "B body performance upgrades" book. This. Also ditch the manual box for power steering and get some fast ratio pitman/idler arms. Stiffen up that chasis!
[Re: Poppinsmoke]
#2625407
02/24/19 01:16 PM
02/24/19 01:16 PM
Posts: 4,404 Michigan
MarkZ
Worthy
Worthy
If you haven't already, tie the frame with connectors. That alone will make night/day difference in how the car handles.
I don't know how Florida roads are down there, but I would advise against 18" wheels. I did all the upgrades to my car (ties, springs, sway bars, stiff steering box, etc) and saved the tires for last. Drove around for a season on 15" Radial T/A tires that were 255 in the back and 235 in the front. The ride was modern and comfortable. The following season I went 18" specifically so I could run big brakes and while cornering improved even more the ride went to [censored]. I've bent two rims already and will probably need to have a few fillings put back in. If I had it to do over again 17" is absolute biggest I would go.
[Re: MarkZ]
#2625451
02/24/19 02:33 PM
02/24/19 02:33 PM
Posts: 30,994 Oregon
AndyF
I don't know how Florida roads are down there, but I would advise against 18" wheels. I did all the upgrades to my car (ties, springs, sway bars, stiff steering box, etc) and saved the tires for last. Drove around for a season on 15" Radial T/A tires that were 255 in the back and 235 in the front. The ride was modern and comfortable. The following season I went 18" specifically so I could run big brakes and while cornering improved even more the ride went to [censored]. I've bent two rims already and will probably need to have a few fillings put back in. If I had it to do over again 17" is absolute biggest I would go. Mark, you might try switching to a really high quality shock before you change wheels and tires. My Coronet rode like an empty dump truck with cheap shocks on it. Once I figured out how to get the Koni shocks to fit on my car the ride improved 200%. I used to wince when I saw a bump coming but now the car just floats over it with a small thump. It is a $500 bill for the good shocks but it sure feels better than getting whacked over the head by each bump in the road.
[Re: Poppinsmoke]
#2625490
02/24/19 03:52 PM
02/24/19 03:52 PM
Posts: 22,695 Bitopia
jcc
Bitopia
I like all your choices.
I would not go smaller on tire, but you didn't mention aspect, and that and TP will effect ride over a wide range.
I would not add the mentioned Rear swaybar at this time.
IMO, a rear swaybar is best sized for solving other less favorable choices one has already made, and installed. There is no downside, to making it your last modification, based on first road testing everything else as a package.
FG hood, and rear mounted battery wasn't mentioned, but would fit with your plan I would think.
[Re: Poppinsmoke]
#2626824
02/27/19 07:01 PM
02/27/19 07:01 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
In m y opinion, for rim/tire size, considering your fenders/wheel openings on the '67 could be a bit small, I'd still favor sticking with 15" rims, good side wall for road bump absorption/ride quality, as well as filling in the wheel openings. A decent 245-60-15 tire (your brand choice) front and rear should be satisfying, using 7" or preferably 8" rims (or wider if you can get the correct centering offset)... this is very critical! For what you're intending, the 17" rims/tires are going to give you unfavorable appearance as your choice to fit will be visibly small within the wheel well. I "cruise" with 15x8 rims, 255-60 front, 275-60 rear... with a very stiff competition autocross suspension, and the ride is just fine. Then, for actual "competition" events, I always swap to short sidewall tires with a larger rim diameter.
Stiffen the suspension (larger TBs, I suggest about 1.12, as anything less and you'll only wonder why you didn't go a little larger). Stiffer leafs and avoid high compressed arch. 2x adjustable shocks will allow you to really fine tune the ride.
IF you're going the route of offset upper control arm bushings, you may as well bite the bullet and get some aftermarket upper control arms that already have the extra caster/camber built in. "Adjustable" UCAs will give you the most tuning, but they are expensive, perhaps beyond what you want.
As you mentioned manual steering, unless you're avoiding the desire for quick maneuvering, make the swap to power steering, and also get a smaller steering wheel... and a better drivers seat that has high side bolster (try different seats until you find a good fitting one for you... like shoes, etc).
Good luck and Mo Power to ya!
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Poppinsmoke]
#2627032
02/28/19 11:50 AM
02/28/19 11:50 AM
jcc
Bitopia
"I prefer my cars to have a manageable throttle induced oversteer if that makes any sense." There is, IMO, no greater nirvana in car handling then to use the right foot gently to rotate one's perfectly balanced car in a turn.
