Couple Pertronix questions....
#2621980
02/16/19 02:00 AM
02/16/19 02:00 AM
Posts: 1,121 State, country, etc.
gss
So I removed an Ignitor II ignition module and Flamethrower II coil from a running 383 and installed it in my 440 Charger. It fired on a few cylinders, then no spark.
I should add that it ran a few months ago with a factory electronic ignition, then a no spark condition appeared. The starter is on a separate switch also. I removed the ballast resistor when I put in the Pertronix. The module mounting plate is well grounded.
1. There is 11.8 volts at the coil + with the key on. When cranking, it goes to -0.14 volts. It should be at least 8 volts when cranking. Why would this happen?
2. When I run a wire from the battery + to the red wire from the Ignitor, I still get no spark. Does this mean the module is junk?
TIA
Re: Couple Pertronix questions....
[Re: gss]
#2621992
02/16/19 02:27 AM
02/16/19 02:27 AM
sounds like the Ignitor ran fine on the 383 & the ignitor & the electronic ign both has issues on the 440 so the wiring issue is there. I would confirm all the connections/terminals as the ignitor/coil would need to be fed 9+ volts in crank/run. Grab your meter & a helper to hold the key & you can pull the yellow wire off of the starter relay to disable the starter for your testing then when you find/fix the poor connection plug it back in & see if it starts/check cranking voltages as needed. EDIT 9+ voltage in "crank" & close to charging voltage in "run" (13+).
[Re: gss]
#2622201
02/16/19 04:31 PM
02/16/19 04:31 PM
Posts: 25,743 Rio Linda, CA
John_Kunkel
No volts when cranking means the IGN2 circuit (the brown wire) is dead; check the firewall bulkhead connector.
[Re: John_Kunkel]
#2622330
02/16/19 10:18 PM
02/16/19 10:18 PM
gss
No volts when cranking means the IGN2 circuit (the brown wire) is dead; check the firewall bulkhead connector. The bulkhead connector is already bypassed. I found a bad connection and now get 9.5V cranking. Still no spark which is no surprise as I don't use the start position on the ignition switch. I just turn the key to run and hit the starter button. I suspect the Pertronix unit is cooked but apparently there is no way to bench test it.
[Re: Andrewh]
#2623289
02/19/19 01:23 PM
02/19/19 01:23 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
If the key is left in the run position for several minutes it's possible to burn up the Hall cell and create a no start condition. Last time I checked, Pertronix doesn't give the exact length of time required to toast the cell.
You should have a full 12v at the coil with the key briefly in the run position to verify the voltage.
