Re: School me on center counter weighted cranks
[Re: Dragula]
#2622490
02/17/19 11:42 AM
02/17/19 11:42 AM
Posts: 4,205 New York
polyspheric
I see i've exceeded the audience's attention span... again. I'll try to use more slang and fewer facts in future.
the counter weights where offset to help longevity for high RPM I leave mine home to save weight.
Boffin Emeritus
[Re: sgcuda]
#2622551
02/17/19 03:24 PM
02/17/19 03:24 PM
Posts: 4,457 Washington
madscientist
Washington
Why is expensive Mallory weight always added to a crankshaft counterweight? Why couldn't the underside of a piston or the bottom of a rod cap be lightened instead? The trick is to keep it as light as possible, isn't it? Why keep adding weight? I see this on tires in the dealership. People that have had their tires balanced several times in their life. Some come in with weights all over the inside of the rim. We all know that this is laziness on the part of the tech balancing the tires. Can the same be said for crank balancing? If you are adding weight to a counter weight, it's because it's too light. You can't take that much out of a rod cap or a piston unless the piston is junk. Let's say all you need is 15-20 grams of Mallory. You ain't going to find that much weight to remove between the rods and the Pistons unless they are just flat out garbage.
[Re: polyspheric]
#2622577
02/17/19 04:33 PM
02/17/19 04:33 PM
Posts: 287 PA
Harry's Taxi 2
PA
the counter weights where offset to help longevity for high RPM I leave mine home to save weight. Maybe less emphasis of your college degree would be more helpful.... if you actually do have an understanding of that which you speak. long on words indicates a shortage of understanding.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: Dragula]
#2622608
02/17/19 05:35 PM
02/17/19 05:35 PM
polyspheric
What a rude little boy you are. You asked the same question several times, but are unable to understand that there is no definitive answer: you're responsible for your own decisions. Which "college degree" are you referring to? Incomplete comprehension indicates a shortage of intelligence.
Boffin Emeritus
[Re: madscientist]
#2622612
02/17/19 05:40 PM
02/17/19 05:40 PM
sgcuda
Why is expensive Mallory weight always added to a crankshaft counterweight? Why couldn't the underside of a piston or the bottom of a rod cap be lightened instead? The trick is to keep it as light as possible, isn't it? Why keep adding weight? I see this on tires in the dealership. People that have had their tires balanced several times in their life. Some come in with weights all over the inside of the rim. We all know that this is laziness on the part of the tech balancing the tires. Can the same be said for crank balancing? If you are adding weight to a counter weight, it's because it's too light. You can't take that much out of a rod cap or a piston unless the piston is junk. Let's say all you need is 15-20 grams of Mallory. You ain't going to find that much weight to remove between the rods and the Pistons unless they are just flat out garbage. But the same 15-20 grams split between 8 pistons and 8 rods might be doable. Does anyone actually know the relationship between rod/piston weight relative to where 1 weight is added to a crankshaft?
[Re: Dragula]
#2622666
02/17/19 08:08 PM
02/17/19 08:08 PM
polyspheric
For this method, in a V8 with 90° bank angle, the relationship: balance weight = 100% of rotating mass + 50% of reciprocating mass. Other engines vary all over the map.
Not that easy. A connecting rod has, by popular convention, its weight divided into reciprocating (top) and rotating (bottom) components. The line of division is the center of gravity. Missing from this equation: a really long rod (3:1 ratio) has most of its reciprocating thrust in the vertical plane, a short rod (1.3:1) has a far larger horizontal component. Conventional balancing completely ignores this (but it's critical to motorcycle engines).
Boffin Emeritus
[Re: polyspheric]
#2622669
02/17/19 08:13 PM
02/17/19 08:13 PM
Posts: 287 PA
Harry's Taxi 2
PA
What a rude little boy you are. You asked the same question several times, but are unable to understand that there is no definitive answer: you're responsible for your own decisions. Which "college degree"(that explains a lot) are you referring to? Incomplete comprehension indicates a shortage of intelligence. Son, Incomprehensive explanation indicates a shortage of intelligence.
[Re: Dragula]
#2622748
02/18/19 12:02 AM
02/18/19 12:02 AM
polyspheric
You didn't find a complete answer to your question in my statement? Not my job.
Boffin Emeritus
[Re: Dragula]
#2622873
02/18/19 12:30 PM
02/18/19 12:30 PM
polyspheric
Translation: "I didn't sit in a room while someone read prepared text to me until I could repeat it". Anyone have a different description for a degree? Hint: none of them involve getting under a car, do they?
Boffin Emeritus
[Re: dthemi]
#2622874
02/18/19 12:31 PM
02/18/19 12:31 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Man, I hate it when it's cold outside. Everybody gets all testy lol.
The long and short of it is this. You typically only find center weights on expensive cranks, designed by smart folks. Bryant, and winberg to me are top of the heap of the stuff we all use. They have suggested them for one application, and recommended against in others. So if you're wondering how to order your 3 to 5 thousand dollar crank, either of those shops will shoot you straight without any regard for making more money. A benefit of dealing with top, established shops that really care about reputation, and quality. Thanks Dt Hemi for some real world insight on a interesting subject
[Re: polyspheric]
#2622963
02/18/19 04:29 PM
02/18/19 04:29 PM
Posts: 43,099 Bend,OR USA
Translation: "I didn't sit in a room while someone read prepared text to me until I could repeat it". Anyone have a different description for a degree? Hint: none of them involve getting under a car, do they? That sounds exactly like some of the electrical engineers I had to deal with while working for the telephone company that knew nothing about customer service or dealing with them
[Re: Dragula]
#2622970
02/18/19 04:49 PM
02/18/19 04:49 PM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
UGH...Never gonna understand why some folks get so butthurt over some of this stuff.
As for the question at hand. A center counter weighted crank is always better IF it is needed for your application..
[Re: Dragula]
#2623013
02/18/19 06:35 PM
02/18/19 06:35 PM
Superfreak
Superfreak
So what would be the applications for a Center counter weighted crank?
[Re: dvw]
#2623348
02/19/19 03:25 PM
02/19/19 03:25 PM
Posts: 9,983 Frostbitefalls MN (Rocky&Bullw...
gregsdart
$3000 crank in a stock block? Seems backwards to me. Doug,after cracking one $800 crank in 100 runs, and chewing up the maincaps in my nice new megablock back in 05, i spent 2300 for a Crower ccw. I figure guys that are somewhat commited to stock blocks might find it and reasonable alternative if it doubles or triples the life of thier block. A busted block also means a lost race and or weekend, all that machinework and parts, and block cores that are getting tougher to find.
