Low offset/wide wheels: I need ideas... #2621306
02/14/19 03:15 PM
02/14/19 03:15 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I'm currently running an 18x9 6.18" BS wheel with a 1" hub centric spacer. The wheels are +30mm offset. The set up is the same all around right now with a 275/40-18.
The front is the biggest issue. I've got the 14.25" rotor with a viper caliper. It currently clears.
The rear is easy, I've got about 2.5" inches from the fender lip and I still need to roll the lip and possibly raise the outer wheelhouse up a little since the car is low.
I'm not thrilled about the spacer. I'd like to get to a wheel set up that only needs maybe a 3/8" steel spacer up front purely for clearing the calipers, but anything less than the current 1" bolt on spacer is fine if the wheels are a compromise on price.
I just want a dark set of wheels to hide brake dust.
Right now I've got a few options:
American Racing VN215 at $200 each. 18x9 ET0 5" backspace
Enkei RPF1 18x9.5 ET15 at $360 each
ET Mags LT-III in 18x10 for $375 each. (I just sent an email out and these are my top choice, providing that they can get the shelf wheel to work for me.)
I want a 5 spoke or multi spoke minilite style wheel. The Enkeis will work from a performance and weight standpoint, but they will look a little off on the car. I think the black gloss and a red caliper will be nice to look at.
What other options do you all know of out there? Any first hand experience with the ET wheels?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Low offset/wide wheels: I need ideas... [Re: AlexP] #2621642
02/15/19 01:18 PM
02/15/19 01:18 PM
moparx  Offline
the only experience i have with ET wheels is the unilug style way back in time, and a set of modern ET3 reproduction wheels for my hot rod in 15x15 size. [big "D" window slot wheels used on top fuel and funny cars in the early 70's]
the unilugs were just awful, especially when the nuts came loose and the washers goofed up the holes they sat in.
the reproductions i had custom made for my application, built in california. while somewhat expensive, they are VERY nicely made and have only .004 TIR, which i find astounding with a wheel that size and backspacing welded up to order.
hopefully, the new style ET's out there are as good as the reproductions i purchased.
Re: Low offset/wide wheels: I need ideas... [Re: AlexP] #2622266
02/16/19 07:28 PM
02/16/19 07:28 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
If the 1" spacer is your main "problem", I wouldn't second guess it for a second. If you want to change wheels to change wheels, then go for it!
2020 RAM 1500
Re: Low offset/wide wheels: I need ideas... [Re: GoodysGotaCuda] #2623199
02/19/19 02:50 AM
02/19/19 02:50 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
It's a little bit from column A and a little bit from column B.
Re: Low offset/wide wheels: I need ideas... [Re: AlexP] #2623238
02/19/19 10:53 AM
02/19/19 10:53 AM
Connecticut, USA
MRGTX Offline
MRGTX  Offline
Connecticut, USA
Forgestar offers a pretty broad range of offsets. Have you given them a look? The only possible downside to them is that not all of their styles are available in 18”.
https://www.forgestar.com/wheels/rotary-forged-monoblock-series/cf5/
