Re: Looking for some Cam Advice [Re: NachoRT74] #2619071
02/09/19 02:52 PM
02/09/19 02:52 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Originally Posted By NachoRT74
what about the crower 271HDP ?
there is something about Crower grinds that I like a lot!!! ( per specs, not experience ). Personally I have the 282HDP which is somehow an "Hemi grind" modern version. I was initially to use the Purple 280/.474
https://www.crower.com/camshafts/mopar-350-440-b-compu-pro-hydraulic-cam-271-hdp.html
Or maybe 267HDP, one step lower
https://www.crower.com/camshafts/mopar-350-440-b-compu-pro-hydraulic-cam-267-hdp.html
I have a Crower 271HDP in a near stock 383. It really needs a slightly higher stall converter than stock. It seemed a bit soft below 2,500 RPM but that is at my 5,000+ ft altifude. At sea level it might be better. I thought it was just too much of a comprimise cam. Just slightly too big hurting low end (with stock converter) and although it pulled smooth from 3,000-6,000 it did not pull as hard as something like the Mopar 284/0.484" cam. I never tried advancing the cam which should have helped the low end torque. I may try that in the future as the engine is on the stand, and I was going to put some closed chamber heads on it to get more compression.
If I was looking for a cam to work with the stock converter, gear, compression and such then I would keep it mild and use something like the Hughes SEH1620BL cam.
On the 383, if you want to use a large cam, be careful with using the Speed Pro / Sealed Power L-2315 piston as they don't have any valve reliefs. Also, with greater than 0.500+ cam lift, might want to use adjustable rocker arms.
Re: Looking for some Cam Advice [Re: blonby] #2619115
02/09/19 05:02 PM
02/09/19 05:02 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
well maybe, you are the experts smile ... the 282HDP I have is on a 451 stroker with 175K MP converter
Re: Looking for some Cam Advice [Re: blonby] #2619371
02/10/19 02:41 PM
02/10/19 02:41 PM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
I suggest Bullet cams, great guys to talk to!
