Re: Neon [Re: 71birdJ68] #2617513
02/05/19 10:18 PM
02/05/19 10:18 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
The only way to know for sure is go the local Mopar dealer and have them run the vin number.
Anything else will be just a guess , regardless of known susp pkg or not
Re: Neon [Re: 71birdJ68] #2619483
02/10/19 06:31 PM
02/10/19 06:31 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I don't think a spring used in a strut will affect the height of a car, the strut will open so much in height and with that said, the strut length will be the height so a weaker spring will compress alot more to give you that sagging look. So I believe you would look for a spring that supports less weight.. like a used one..just saying
