mopar dude gas tank woes #2611264
01/23/19 10:14 PM
01/23/19 10:14 PM
Lethbridge, AB, Canada
dangina Offline OP
dangina  Offline OP
so been fighting this issue the past two years, everytime i fill up or stop awhile it dumps out about 2-4 litres of fuel out the vent tube, tried taking the hose up into my trunk so its higher than the filler neck, its slightly better but this is getting tiresome pics show with what I am working with, any suggestions?
Re: mopar dude gas tank woes [Re: dangina] #2611266
01/23/19 10:14 PM
01/23/19 10:14 PM
dangina Offline OP
dangina  Offline OP
btw 1971 roadrunner the only vent is the middle one on the pump flange
Re: mopar dude gas tank woes [Re: dangina] #2611284
01/23/19 10:49 PM
01/23/19 10:49 PM
BDW Offline
BDW  Offline
Fill up the tank less?
Crappy solution I know, but your vent is lower than the high point of the tank.
Cap that tube and add a vent to a top corner.
Re: mopar dude gas tank woes [Re: dangina] #2611304
01/23/19 11:21 PM
01/23/19 11:21 PM
Are you routing the vent hose back into the filler pipe? If not, why not work up
You might want to add a complete loop in the hose also up high above the entry into the filler pipe also up twocents
Re: mopar dude gas tank woes [Re: Cab_Burge] #2611371
01/24/19 01:31 AM
01/24/19 01:31 AM
dangina Offline OP
dangina  Offline OP
Thought about this, i think I need to add a one way valve in there as well
