Carb linkage ?
#2610461
01/22/19 03:29 PM
01/22/19 03:29 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
In uncharted waters again. Have a Hemi that is going to use an old Weiand TR. Sideways 4150's. What is a good throttle linkage kit to use. There are a few universal available. Just would like to be sure seeing they are good money for handful of parts. Thanks much.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
Re: Carb linkage ?
[Re: sixpackbee]
#2610465
01/22/19 03:33 PM
01/22/19 03:33 PM
Posts: 4,457 Washington
madscientist
Washington
The Enderle is probably the easier and cheapest to use.
Re: Carb linkage ?
[Re: sixpackbee]
#2610466
01/22/19 03:33 PM
01/22/19 03:33 PM
Posts: 43,123 Bend,OR USA
Probably the Buchillion (SP?) cable kit would be your best choice I've used the Lokar kit once and know of several others that had a hard time also getting it adjusted the way they wanted them to drive and kick down IHThs
Re: Carb linkage ?
[Re: sixpackbee]
#2610469
01/22/19 03:38 PM
01/22/19 03:38 PM
madscientist
Washington
Evidently I read the OP's post wrong. I thought he meant the linkage and not the throttle cable side of it. Sorry for the confusion.
Re: Carb linkage ?
[Re: madscientist]
#2610480
01/22/19 03:58 PM
01/22/19 03:58 PM
Evidently I read the OP's post wrong. I thought he meant the linkage and not the throttle cable side of it. Sorry for the confusion. Oops, I misread it That is what happens when I assume OP, the Enderle and several other ones not mentioned are excellent kits to use Summit list several good ones
Re: Carb linkage ?
[Re: sgcuda]
#2610931
01/23/19 11:16 AM
01/23/19 11:16 AM
sixpackbee
Western New York
Thanks guys. Ended up buying an Enderle. We'll see how it goes. Hopefully on the dyno in a few weeks.
Re: Carb linkage ?
[Re: sixpackbee]
#2611004
01/23/19 01:30 PM
01/23/19 01:30 PM
Posts: 4,206 New York
polyspheric
If I had an odd application, I'd ask AndyF. If he doesn't make it, he's sure to have some ideas, and perhaps components?
Boffin Emeritus
Re: Carb linkage ?
[Re: sixpackbee]
#2611173
01/23/19 06:52 PM
01/23/19 06:52 PM
polyspheric
Starting from this early, you have a chance to modify how "nervous" the throttle is between idle and tip in by changing the geometry.
Boffin Emeritus
Re: Carb linkage ?
[Re: polyspheric]
#2611355
01/24/19 12:55 AM
01/24/19 12:55 AM
hemi-itis
Starting from this early, you have a chance to modify how "nervous" the throttle is between idle and tip in by changing the geometry. That's always just loads of fun,,,,,,,,,,,,NOT!!!
