Re: rear disc brake / prop valve question conversion
[Re: superchuck]
#2608463
01/18/19 06:41 AM
01/18/19 06:41 AM
Posts: 84 Norway
cudaerik
Norway
You do not need a prop. valve with disc brakes in all four corners, all you need is a distribution block.
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600) 1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600) 1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
[Re: cudaerik]
#2608504
01/18/19 11:42 AM
01/18/19 11:42 AM
Posts: 14,889 up yours
Supercuda
You do not need a prop. valve with disc brakes in all four corners, all you need is a distribution block. What you don't need is a disc/drum combination valve, which is what you have right now. You may, or may not need a proportioning valve depending on how well you did your homework. If you choose the wrong sized rear caliper you may need a proportioning valve to dial out any rear wheel lockup.
[Re: superchuck]
#2608565
01/18/19 01:53 PM
01/18/19 01:53 PM
Posts: 30,989 Oregon
AndyF
My car is disc/ drum and I converting the rear to disc. Can I use the existing prop valve or remove it and install an adjustable one? Thanks You left out too much information so the only answer that fits is "it depends".
