Electrical Issues #2608082
01/17/19 02:46 PM
01/17/19 02:46 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Anyone know if there is a relay or just the switch for the wipers in a '66 Plymouth Fury III? They work with the switch on, but when I try to shut them off, it will intermitteltly make a loud "click" under the dash and the wipers will try to move but only jump about 1/8" and stop. Couldn't see any relays ...
Re: Electrical Issues [Re: jeebis44] #2608090
01/17/19 03:02 PM
01/17/19 03:02 PM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
Each wiper switch, two or three speed, has an internal circuit breaker. That is what you are hearing.
An option would be to unplug the wiper motor while still on the firewall and run the wiper motor with jumpers to rule out the switch. See if there is some sort of binding going on with the linkage.
Re: Electrical Issues [Re: jeebis44] #2608111
01/17/19 03:35 PM
01/17/19 03:35 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Inside the wiper motor is a parking switch, looks like a set of ignition points. When you turn off the switch on the dash, you will keep power through the parking switch until a cam opens the points and breaks the contacts, so the wipers always stop at the park position. Take your motor apart and check the parking switch to see if its burnt or other wise damaged.
Re: Electrical Issues [Re: jwb123] #2608150
01/17/19 04:51 PM
01/17/19 04:51 PM
RapidRobert Offline
RapidRobert  Offline
As said take off the arm to see if the noise/interference is inside or (likely) in the linkage. confirm good motor case ground & as said that the one wire is still hot that makes the motor move the linkage to park when you shut the switch "off"
Re: Electrical Issues [Re: jeebis44] #2608229
01/17/19 07:32 PM
01/17/19 07:32 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
OK thanks folks - will give that a try
Re: Electrical Issues [Re: jeebis44] #2613163
01/27/19 07:53 PM
01/27/19 07:53 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Well I partially disassembled the motor and just cleaned everything out with CRC electronics cleaner. Reassembled and it works fine now. Thanks for the advice!
Re: Electrical Issues [Re: jeebis44] #2613225
01/27/19 10:05 PM
01/27/19 10:05 PM
RapidRobert Offline
RapidRobert  Offline
that is good to hear (we need things to go right on occaision). I gotta do one myself (same symptoms ex no clicking, it just wont park em).
