64 B-Body/Hellcat 6.2 Headers #2606840
01/15/19 11:43 AM
01/15/19 11:43 AM
Jacksonville, NC
RonP Offline OP
RonP  Offline OP
Jacksonville, NC
My 64 440 drag car is about to be Hellcat powered. I just put a Gerst suspension under the front and will be using his conversion mounts.
The car will be keeping the 727.
Looking at TTI 64LHCA-R1C4 headers. Any feedback on these as far as fitment? Looking around I didn't see any other options. Are there any?
Thanks folks.
Re: 64 B-Body/Hellcat 6.2 Headers [Re: RonP] #2607062
01/15/19 06:18 PM
01/15/19 06:18 PM
K
Kiddart Offline
Kiddart  Offline
K
I now that headman makes a set for B-Body but I have no real life experience with them. I had to purchase a set of TTI's for my A-Body.
one thing you can do is see if a set from a srt-8 jeep will fit. more than likely they will the exhaust flange is turned down. lots less money for a set of these. this area of Moparts is full of good knowledge.
Good Luck
Thank you
Kiddart
Re: 64 B-Body/Hellcat 6.2 Headers [Re: RonP] #2607246
01/15/19 11:31 PM
01/15/19 11:31 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
I have this header on the 65 I am building right now. I am using a motor plate but using the specs TTI states for motor placement these headers are REALLY close to the motor mount bracket welded to the K frame. I actually cut the brackets off my K frame to make it easy to get them on and off without beating them up. Other wise they are really close to the pitman arm and fit great everywhere else.
Re: 64 B-Body/Hellcat 6.2 Headers [Re: biff426] #2608051
01/17/19 01:45 PM
01/17/19 01:45 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Ron, i think the only problem is when guys use shumacher mounts with stock k frames. Im not sure how tti mounts differ than Schumacher and your not using a stock K either so its all questionable
Gen 3 power 6.22@110, 9.85@135
Follow @g3hemiswap on instagram
performance only racing, CRT, ultimate converter, superior design concepts, ThumperCarbs
