Re: battery box
[Re: Mr.Yuck]
#2605444
01/12/19 03:38 PM
01/12/19 03:38 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
If you have a fire wall between the interior and the trunk a battery box is not needed.
Re: battery box
[Re: Mr.Yuck]
#2605477
01/12/19 04:41 PM
01/12/19 04:41 PM
Posts: 11,494 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If there is no sheetmetal rear firewall, a sealed box vented to the outside is needed. The Moroso box works great. Box or not, a rear mounted battery needs to be held down by minimum of 2 3/8" studs or bolts to a framerail or framerail mounted tabs/brackets. The box or battery tray can be attached to the floor however you like. Battery hold downs need to go through to the frame.
Re: battery box
[Re: Mr.Yuck]
#2605998
01/13/19 05:32 PM
01/13/19 05:32 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If it has a legit firewall, no box is required. Just proper battery retention.
Re: battery box
[Re: Mr.Yuck]
#2606566
01/14/19 06:57 PM
01/14/19 06:57 PM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
why not use a AGM or gel type battery ? No fluid issues . No need to use a box or vent down here if using this type of battery .
Tex
Re: battery box
[Re: tex013]
#2607073
01/15/19 06:40 PM
01/15/19 06:40 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Not enough dumb comments...yet
Brookeville, Md
Tex Yes I will most likely be using one of those. I have a Optima from Chumpcar... As far as I know it is still good. If not I'll buy another one.
