Re: What brand/type of trans and brake fluid?
[Re: vinnyd76]
#2605345
01/12/19 12:47 PM
01/12/19 12:47 PM
Posts: 12,013 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Any brand +4 or HyGard hydrostat fluid in the tranny and DOT 5 for the brakes.
Master, again and still
[Re: mopars4ever]
#2605397
01/12/19 02:39 PM
01/12/19 02:39 PM
Posts: 1,562 Macomb, MI
vinnyd76
Macomb, MI
I`m going with Dot 5 this time around in my current build since everything will be new. I have it in another car I own and I have had no issues. I used Type F last time in my 904 but I`m not sure what I am going to use this time. Looking to see what others recommend here. I was also told to use DOT 5. I was advise DOT 5 does not damage the paint in the event there is an accident and fluid leaks/spills.
[Re: vinnyd76]
#2605408
01/12/19 03:01 PM
01/12/19 03:01 PM
Posts: 15,826 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I always hear Type F for firmer shifts but not best for the 727.
I go with what trans shop owner of over 30 years here in town tells me to use in my 727 for best durability; Dex/Merc.
Facts are stubborn things.
[Re: vinnyd76]
#2605442
01/12/19 03:36 PM
01/12/19 03:36 PM
Posts: 13,572 md
mopars4ever
md
That`s the main reason I am using it this time around being I will have new paint.
[Re: vinnyd76]
#2605650
01/12/19 11:44 PM
01/12/19 11:44 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
what ever walmart sells...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: vinnyd76]
#2605929
01/13/19 03:49 PM
01/13/19 03:49 PM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
Use walmart brand Type F. You can buy other brands but there isn't much reason to.
[Re: vinnyd76]
#2606198
01/13/19 11:18 PM
01/13/19 11:18 PM
Posts: 601 Mass
charge70
Mass
For brake fluid I use DOT 5.Like others said no paint problems if there is any spillage.The ATF I use is whatever the local parts stores stock but I was told by John K.on this board was to use a 50/50 mix of Dexron and Type F.I've been doing it that way for years without any problems.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: NANKET]
#2606854
01/15/19 12:19 PM
01/15/19 12:19 PM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
There is no letter T in the word DEXRON. WTH is dextron? Some sort of 80's techno fluid?
Cope and his home built trans are pretty comical. Had a friend spec out a complete trans for a 10 second racecar. Burnt up in 2 days at the track. Cope was like, "Oh I had a bad run of valve bodies but thought I had those fixed". Gee thanks CRT! Good to know, I shall keep that in mind.
[Re: challenger70]
#2607519
01/16/19 03:13 PM
01/16/19 03:13 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Cope and his home built trans are pretty comical. Had a friend spec out a complete trans for a 10 second racecar. Burnt up in 2 days at the track. Cope was like, "Oh I had a bad run of valve bodies but thought I had those fixed". Gee thanks CRT! Good to know, I shall keep that in mind. I hope so you awful person!!!!!
