Re: old scool air shocks, Hi Jackers
[Re: Moparnut426]
#2593182
12/17/18 03:26 PM
12/17/18 03:26 PM
Posts: 14,889 up yours
Supercuda
Wonder how them holes got ovaled out?
[Re: TOMRR]
#2593299
12/17/18 07:04 PM
12/17/18 07:04 PM
Supercuda
Air Shocks !!!! You know that, I know that, ... lol
[Re: Moparnut426]
#2593391
12/17/18 10:00 PM
12/17/18 10:00 PM
Posts: 11,894 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Inspect that top shock cross member. I have seen many of them busted because of air shocks. It was never meant to support the weight of the car.
Master, again and still
[Re: sixbbl 69]
#2593553
12/18/18 01:38 AM
12/18/18 01:38 AM
Posts: 10,486 Freeport IL USA
poorboy
Freeport IL USA
had them on 2 road runners for 20 years. never leak and no hole problems.if you know how to install them they won't leak and if you don't put them on a rusty car or a 4.200 lb charger the holes will be fine. I suppose how much you tried to lift the rear of the car to clear tires could have a huge effect on how well the shocks or the holes they were mounted in would last. At the gas station I worked at in the early 70s, we had a guy that insisted we put 145 psi in his 150 lbs max pressure Hi-Jackers. He didn't get very long life out of either the shocks, or the mounting points (didn't much help the tires or rear quarters either). I ran mine at around 80 psi, I didn't have any issues with my rust buckets. Gene
[Re: Moparnut426]
#2593660
12/18/18 10:59 AM
12/18/18 10:59 AM
Posts: 21,050 Niles , Ohio
therocks
Niles , Ohio
Shackles on most will do little to nothing.Most have weak springs and shackles wont lift much if any.Saw many with springs bent under because of shackles.Rocky
Chrysler Firepower
[Re: poorboy]
#2593695
12/18/18 12:16 PM
12/18/18 12:16 PM
Posts: 112 Illinois
sixbbl 69
Illinois
had them on 2 road runners for 20 years. never leak and no hole problems.if you know how to install them they won't leak and if you don't put them on a rusty car or a 4.200 lb charger the holes will be fine. I suppose how much you tried to lift the rear of the car to clear tires could have a huge effect on how well the shocks or the holes they were mounted in would last. At the gas station I worked at in the early 70s, we had a guy that insisted we put 145 psi in his 150 lbs max pressure Hi-Jackers. He didn't get very long life out of either the shocks, or the mounting points (didn't much help the tires or rear quarters either). I ran mine at around 80 psi, I didn't have any issues with my rust buckets. Gene you hit the nail on the head Gene.i have had HyJackers on my mopars since 1969 and never a problem.we don't have rust buckets here in central IL. Jerry
