Re: Rallye Dash vs Standard Dash -E BODY Dash diff. - UPDATE
[Re: MONC]
#2602471
01/06/19 04:21 PM
01/06/19 04:21 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
To me ( per what I can see ) the standard dash cluster fits just right over the bezel, not throught, so the bezel could be the same for both! I can't see any round cut on bezel to fit the speedo section, but a speedo shadow/gap over the bezel
[Re: spk2go]
#2602564
01/06/19 07:56 PM
01/06/19 07:56 PM
Posts: 2,252 New York
rarefish
The standard dash has a curved cut out for the large speedo and the rallye is straight. just for correctness the picture of the rallye gauges has the road lamp switch in the wrong location. Should be under the dash. I think you are looking at the rear speaker fader?
[Re: rarefish]
#2602570
01/06/19 08:12 PM
01/06/19 08:12 PM
Posts: 3,653 The Historic Hudson Valley
MONC
The standard dash has a curved cut out for the large speedo and the rallye is straight. just for correctness the picture of the rallye gauges has the road lamp switch in the wrong location. Should be under the dash. I think you are looking at the rear speaker fader? I believe spkgo is referring to the pic second 70 posted of the rallye dash that has the road lamp switch in it. Yes it was factory mounted under the dash , but probably remounted there for ease of use.
Mopar Or No Car
[Re: MONC]
#2602572
01/06/19 08:13 PM
01/06/19 08:13 PM
MONC
Can someone post a picture of the standard dash with a standard dash bezel? Would like to compare how the bezel looks with the dash cluster.
Mopar Or No Car
[Re: spk2go]
#2602782
01/07/19 03:28 AM
01/07/19 03:28 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Look at second 70’s picture where the road lamp switch is. That is odd on a rallye dash? here's the location on 70 and 71 STANDARD dashes
[Re: MONC]
#2602818
01/07/19 10:48 AM
01/07/19 10:48 AM
Posts: 1,499 Bradenton, Fl 34203
Kilroy was here
Bradenton, Fl 34203
Many years ago it took me about three hours to put a rally Dash into my standard - 73 Challenger, with a friend helping me.. Actually it's pretty easy had to wire up the tach. And the heater control is different. And I use the factory wiring diagram that really help
[Re: DAYCLONA]
#2602942
01/07/19 02:39 PM
01/07/19 02:39 PM
Posts: 1,696 central il.
second 70
central il.
Look at second 70’s picture where the road lamp switch is. That is odd on a rallye dash? here's the location on 70 and 71 STANDARD dashes Good eyes the switch is not in the usual location.Since the car was a standard dash the frame wasn't drilled for the normal location so instead of drilling the frame and knowing it wasn't going to be in the right spot anyway I put it where I thought it looked the best. Mike
