440 Main Bearings #2591412
12/13/18 05:34 PM
12/13/18 05:34 PM
TN
SCATPACK 1 Offline OP
TN
Is there a company that still makes a full groove Main Bearing set for a 440 or Hemi mains?
Spent some time with the NAPA parts guy and did not find anything that had full grooves. 3/4 and half grooves is all we could find.
I want to use the full groove set if possible to take advantage of full time oiling to the rod bearings.
Any Mfg or part numbers would be greatly appreciated.
Old Geezer Racing
Re: 440 Main Bearings [Re: SCATPACK 1] #2591438
12/13/18 06:39 PM
12/13/18 06:39 PM
John_Kunkel Offline
John_Kunkel  Offline
Re: 440 Main Bearings [Re: SCATPACK 1] #2591445
12/13/18 07:00 PM
12/13/18 07:00 PM
Supercuda Offline
Supercuda  Offline
Clevite
Enginetech
The Mancini ones linked are for the early thrust diameter blocks. The ones I linked are for the later, larger diameter thrust.
Don't be the exception.
Re: 440 Main Bearings [Re: SCATPACK 1] #2591446
12/13/18 07:02 PM
12/13/18 07:02 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
MAHLE/CLEVITE MS2324P
Re: 440 Main Bearings [Re: ZIPPY] #2591449
12/13/18 07:11 PM
12/13/18 07:11 PM
Supercuda Offline
Supercuda  Offline
Small diameter thrust bearing. You can use them in the later blocks but you give up some thrust bearing capacity.
Re: 440 Main Bearings [Re: SCATPACK 1] #2591477
12/13/18 08:26 PM
12/13/18 08:26 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Federal Mogul's 119M is a tri-metal bearing w/ their "3/4 groove" design, although it's more like 5/8 if you ask me. It combines a wide groove like the traditional Hemi main bearings, but maintains more bearing surface area where the loads are the highest.
Only comes in the small-thrust style, but works in either small-thrust of large-thrust applications, plus it's narrowed just enough to work w/ full-radius cranks, too. The one limitation IMO is that it's only available as standard and .010" undersize.
Re: 440 Main Bearings [Re: Supercuda] #2591501
12/13/18 09:09 PM
12/13/18 09:09 PM
John_Kunkel Offline
John_Kunkel  Offline
OP didn't state the year of his block.
Re: 440 Main Bearings [Re: Supercuda] #2591503
12/13/18 09:14 PM
12/13/18 09:14 PM
TN
TN
Originally Posted By Supercuda
Clevite
Enginetech
SuperCuda, Have you had any experience with the Aluminum bearings that Engine Tech refers to?
Old Geezer Racing
Re: 440 Main Bearings [Re: John_Kunkel] #2591504
12/13/18 09:16 PM
12/13/18 09:16 PM
TN
TN
You are correct John I did not.
I have a 72 and a 73 and a 74 440 block to choose from. I am thinking the 72 is a better block just based on how it has been stored the last 20 years. The other 2 blocks are showing some rust in the cylinder walls.
Old Geezer Racing
Re: 440 Main Bearings [Re: John_Kunkel] #2591541
12/13/18 10:48 PM
12/13/18 10:48 PM
Supercuda Offline
Supercuda  Offline
True, which is why I pointed out the differences, didn't know if he was aware. As I mentioned, you can use the early style in the later blocks, but lose some thrust capacity. Will that matter? Chrysler thought so at the time.
Re: 440 Main Bearings [Re: SCATPACK 1] #2591543
12/13/18 10:51 PM
12/13/18 10:51 PM
Supercuda Offline
Supercuda  Offline
Nope, last time I built an RB I used Clevite 77's and we had to buy two sets to get full main grooves.
Re: 440 Main Bearings [Re: SCATPACK 1] #2591553
12/13/18 11:01 PM
12/13/18 11:01 PM
TN
TN
Well Riddle me this Brad, or Zippy, or Super Cuda or John. I can not remember for certain. So what year did they go to the larger thrust bearing surface? I wan't to think it was in 72 with the introduction of the 400 block, but again, I am not completely certain.
Thanks again for each and everyone's help in my search.
Merry Christmas Jerry
Old Geezer Racing
Re: 440 Main Bearings [Re: SCATPACK 1] #2591554
12/13/18 11:04 PM
12/13/18 11:04 PM
Supercuda Offline
Supercuda  Offline
1974 was the change
Re: 440 Main Bearings [Re: Supercuda] #2591579
12/14/18 12:02 AM
12/14/18 12:02 AM
TN
TN
Well. I was really off on what I thought. thanks for clearing my memory up for me Super Cuda.
Old Geezer Racing
Re: 440 Main Bearings [Re: SCATPACK 1] #2591626
12/14/18 01:56 AM
12/14/18 01:56 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
No need for full groove mains. 6 years with over 500 passes running 1/2 groove. 7200 rpm, 4.5" stroke. Rod bearings always look like new with 1/2 groove.
Doug
