1966 Plymouth Light Bulb Socket #2591195
12/13/18 07:58 AM
12/13/18 07:58 AM
Akron, Ohio
VegasCharger Offline OP
Akron, Ohio
I'm parting out a '66 Plymouth Belvedere and came across this(pics below) in a heap of small misc parts in a box in the trunk.
Is it related to this car? Courtesy light?
Thanks in advance. beer
Re: 1966 Plymouth Light Bulb Socket [Re: VegasCharger] #2591480
12/13/18 08:37 PM
12/13/18 08:37 PM
RapidRobert Offline
RapidRobert  Offline
I dont have an ans but you might check the diagrams at www.mymopar.com & see what you see.
Re: 1966 Plymouth Light Bulb Socket [Re: RapidRobert] #2591658
12/14/18 04:15 AM
12/14/18 04:15 AM
Akron, Ohio
Akron, Ohio
Thanks beer
Re: 1966 Plymouth Light Bulb Socket [Re: VegasCharger] #2591712
12/14/18 11:06 AM
12/14/18 11:06 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I've taken a bunch of stuff apart over the years and can't ever remember seeing one with a spade terminal connected to it like that one has... twocents
...FAFO...
Re: 1966 Plymouth Light Bulb Socket [Re: skicker] #2592079
12/14/18 09:56 PM
12/14/18 09:56 PM
Akron, Ohio
Akron, Ohio
@ skicker
Thanks!! beer
Re: 1966 Plymouth Light Bulb Socket [Re: VegasCharger] #2592381
12/15/18 03:24 PM
12/15/18 03:24 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
looks like a reverse lite in the rear bumper.
The spade connector is strange.
Maybe a repair made decades ago.
I have mechanical Aptitude.
I can screw up anything.
Re: 1966 Plymouth Light Bulb Socket [Re: VegasCharger] #2592638
12/16/18 03:03 AM
12/16/18 03:03 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The reverse lights are in the trunk lid and they had a regular spade terminal for the ground wire to plug into. The tang on that socket does not look like a terminal. 1966-67 coronets have reverse lights in the bumper with power wore only, ground is through the lamp housing to the bumper.
Here a pic of an under dash courtesy lamp. 2 wires in the top. The tabs to hold it in the bracket look the same.
