Re: Starting mockups for a 572 build... ugly pictures
[Re: ZIPPY]
#2769692
04/29/20 11:44 PM
04/29/20 11:44 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
I only mixed 8 ounces of paint (+ hardener and reducer), But after one tack coat and two full wet coats I was done with the engine.
Still had about 2 tablespoons of mixed paint in the cup. What to do?
Rather than throw it out, I fogged most of the wix/carquest oil filter stash real quick to Use it up on something.
This thing has sure come a long way. My hat is off to the experts who do this successfully for a living. That oil pan MIGHT get hit by the center link, it looks deep in that area, I had one like it & it hit on my B wedge.
[Re: CSK]
#2769718
04/30/20 07:48 AM
04/30/20 07:48 AM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
Hope not, but guess it could happen and it wouldn't hurt to be prepared. It looked to be a copy of the 971/Moroso deep sump currently in the car, eyeballing it it seemed pretty close but I'll check it again with a measuring tape. If it's not going to work I'll try one with a passenger side kickout.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2769774
04/30/20 10:52 AM
04/30/20 10:52 AM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
[Re: DynoDave]
#2769801
04/30/20 12:20 PM
04/30/20 12:20 PM
ZIPPY
S.E. Michigan
thanks Dave, don't be a stranger!
Rich H.
Esse Quam Videri
[Re: AndyF]
#2769837
04/30/20 02:31 PM
04/30/20 02:31 PM
ZIPPY
S.E. Michigan
As an influence for a long time, I do like your enthusiasm Andy and totally agree on timing/public taste at the moment.
Folks were literally taking close ups of the rust last year at the track, and I got a ton of positive remarks.
Just want to take care of the front end of the car right now. It'll have both primer and patina going on for awhile when the engine is fit in there and driven a bit.
Seems like it should be a pretty mild beast with an exhaust on it, compared to the 451.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2770084
05/01/20 10:34 AM
05/01/20 10:34 AM
DynoDave
MICHIGAN
thanks Dave, don't be a stranger! I'd offer to come by and help you drop that thing in place, but that would be hard to do from 6 feet away! I'm sure you have plenty of help, but if you need an extra pair of hands, don't be afraid to ask.
[Re: DynoDave]
#2770401
05/02/20 11:26 AM
05/02/20 11:26 AM
ZIPPY
S.E. Michigan
Thanks Dave. Managed to get the pulley alignment within 1/32nd". Thanks to the poster who suggested to use tubing in the V grooves on one of my 800 other threads. Between the tubing and having the motor plate/creating a nice flat measuring point, that really worked out great. Alternator is from a 1991 D150 318, 120 amp Denso. It wasn't designed to work with Andy's bracket but is really easy to set up. If anyone wants the "recipe" you drill the bracket out to 3/8, push the alt sleeve out the back flush with the inside of the ear, make a 1.040" spacer for the front, and use a 4.5" long 3/8" bolt with a nut on the back. March WP pulley, Andy's crank pulley spacer, Moroso crank pulley with .120" cut off in a lathe. So many have told me the Moroso pulley doesn't work...I've used it since 2001 Hopefully it works on this deal.
Rich H.
Esse Quam Videri
Re: Starting mockups for a 572 build (trying better pics)
[Re: ZIPPY]
#2772798
05/09/20 11:06 AM
05/09/20 11:06 AM
ZIPPY
S.E. Michigan
Pictures trying to be less ugly, and partially succeeding.
Covid-572: Pandhemi, born on 4/26/20.
That's a wrap for now.
Rich H.
Esse Quam Videri
[Re: DUSTER_340]
#2772839
05/09/20 12:12 PM
05/09/20 12:12 PM
ZIPPY
S.E. Michigan
Looks awesome Rich, cant wait to have mine to that state.
Thank you Bob! Please let me know if I can somehow be of any help.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2820630
09/14/20 02:10 PM
09/14/20 02:10 PM
Posts: 13,356 Marion, South Carolina [><]
an8sec70cuda
Looks awesome Rich! One of your threads I completely missed out on while I was on shut down leave...but we kept up via FB. How's the car coming?
[Re: ZIPPY]
#2820644
09/14/20 02:37 PM
09/14/20 02:37 PM
ZIPPY
S.E. Michigan
What might be more important that "what is"......What is NOT.
In other words: What DIDN'T work? Nobody ever talks about that! It isn't exactly a Glamorous topic.
Quite a bit did not work out like I originally planned or hoped. I had to try a few things and really look at them/think about them to decide I didn't want to go that way.
-The 572 actually started as a 528. I had bought a new set of Wiseco/MP pistons for $250, and a new set of Scat Rods for $400. Later on the Diamond 572/Indy crate piston set came up for sale for an incredible price, and that sealed the deal. MP pistons sold off for a song. (I'll use the Scat rods in a near-stock type of engine later on). I was thankful for this as I was close to buying a 4.150 crank, and ended up with 4.500.
-The older design 110-M MP aluminum heads. I had hoarded several, almost all of them needed rework, and in the end I decided I'd be better off with new heads from an airflow and cost perspective. I recently sold almost all of them off. There is nothing wrong with them, they can definitely run great. But, I would have had to repair mine, drop alot of money into them for prep, and probably wait at least another year for that one CNC shop to pull the big numbers.....
-My first choice of 272 @ .050 endurance roller cams. Didn't have enough piston to valve clearance, locked it up. Wasn't about to mess with the pistons any further. I was a little disappointed, but considering the Diamond pistons I'm using cost 75% less than customs, and this is a street engine first....no big deal. One local guru I have the utmost respect for told me I needed to take about 16 degrees @ .050 out of it. I compromised at 12. The second smaller cam took care of that problem.
-The little brass tube pressed into Victor heads for exhaust pushrod clearance/so they can hog out the intake port is OK with stock rocker arms, but would not work with Indy exhaust rollers. Another thing that had a negative effect on exhaust pushrod clearance was the use of lifters that were near standard height (I mocked up flat tappets for visual aid purposes) with the same rocker combination. You can't just grind for more PR clearance because there's only a thin brass tube there, there's nothing to grind on. Of the pieces I worked with, Comp 861 lifters were the best fit overall with the two rocker combos I had. I have to imagine Comp 892 would probably have also worked (I believe they are taller than stock which is needed) but did not have any to mock up.
-If you follow the story, the oiling system was a conundrum. I was set on staying with internal pickup and had to take the time to mock up a stock style pickup + attempt to clearance it for my combination of parts before deciding I didn't like it, and it would be better to use the World/MP block external pickup provision instead. Remember this is a 4.500x4.500. If you use a shorter stroke, you'll have less of an issue or maybe none.
-The oil pan. A shallow pan is nice for street use so I looked into that, close enough to map out the oil level and mark the pan. Eventually had to admit to myself I hadn't run less than 8 quarts even with my Wedge engine, since 2001 and that it would probably be smart to use AT LEAST that with the Hemi.
-Having never used race connecting rod bearings before, I got totally lost with those before I was straightened out (right here, and also by the rod manufacturer) On the upper/lower markings + arranging them to have the chamfers facing the right way. Before looking into that and admitting my lack of experience, I had no idea about that. Prior to this I only used stock replacement style bearings (clevite P, sealed power, stuff like that), which do not have an upper and lower. This wasn't a parts thing, it was a learning opportunity. I'm also not accustomed to having quite so many choices for bearings which only happens when you use Chevy journal dimensions.
-I had pushrod length 100% dialed in where I wanted it, and then decided to upgrade the rocker adjusters.......and that meant I had to do that job twice. It cost me time, but was another learning opportunity. A street application probably doesn't need the adjusters I installed but it seemed like a good idea anyway.
There is more but I have to stop for now.
Really this build was a great learning experience overall.
I also hope to do some different Gen 2 Hemis later on and have made tentative plans.
A friend suggested I start a youtube series "a hemi for regular gearheads" or something like that. I'm not sure anyone would care enough to watch it.
Rich H.
Esse Quam Videri
[Re: an8sec70cuda]
#2820647
09/14/20 02:47 PM
09/14/20 02:47 PM
ZIPPY
S.E. Michigan
Looks awesome Rich! One of your threads I completely missed out on while I was on shut down leave...but we kept up via FB. How's the car coming? Hi Chip, thank you. Not a whole lot has changed lately, but I have had the front sheetmetal off the car for awhile now have welded in a new right inner fender, have done a little rust repair besides. The backside of the fenders/underside of the inner fenders/rails are painted and I almost have the class A side of the fenders ready for primer. Been getting alot of practice repairing sheetmetal, since I can't strip the whole car and put it on a rotisserie I'm going to work front to back in sections. Sold my truck and got sidetracked by new/used truck purchase + and a few other projects and am almost back to working on the car. The 572 sits under a plastic sheet, on the engine stand. I'm thinking of making an engine dolly for it just to make it smaller and more compact/a little easier to roll around.
Rich H.
Esse Quam Videri
