Re: Would you run a solid roller with ductile rockers?
[Re: viperblue72]
#2589967
12/10/18 06:42 PM
12/10/18 06:42 PM
Posts: 20,145 PA.
pittsburghracer
I ran a set of unbushed rockers on my 440 years ago with a 695 mushroom tapping cam for years. Strip only car but we raced 2-3 times a week.
[Re: viperblue72]
#2589971
12/10/18 06:53 PM
12/10/18 06:53 PM
Posts: 9,982 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Seems to me it will be about the intensity of the lobes, and how much they stress the rockers, not what type of lifter they use. A street roller would probably be easier on the rockers than a race flat tappet. My geuss is an endurance roller lobe would be worth looking at, and find some of the OLD big name engine builders from the 60s or early 70s, as they probably tried everything. I know for instance that Crane Gold rockers will stand up to a .750 lift superstock roller, at least for a while. I broke the crank before i put many runs on that setup.
[Re: viperblue72]
#2589975
12/10/18 07:07 PM
12/10/18 07:07 PM
Posts: 14,491 So. Burlington, Vt.
“I wouldn’t”, but I’m sure many have.
[Re: viperblue72]
#2589981
12/10/18 07:18 PM
12/10/18 07:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Pbody- I plan to run something that is approximately.400 lobe lift. At about .400 lift I would.. sweep is minimal if its set up right.. assuming this is some street grind cam
[Re: viperblue72]
#2589990
12/10/18 07:38 PM
12/10/18 07:38 PM
Posts: 4,457 Washington
madscientist
Washington
That rocker is better than most of the junk that was sold out there.
If it's bushed, make sure it has full oil and keep idle oil pressure and flow up. I've run .750 net rollers and 340 on the seat with those rockers.
If you break that rocker, it's a geometry issue, or some other problem like a binding issue.
I'd pay to run those before I'd use a set of HS rockers for free.
[Re: viperblue72]
#2590054
12/10/18 09:16 PM
12/10/18 09:16 PM
Posts: 4,205 New York
polyspheric
Careful inspection for minor surface imperfections. If any catch your fingernail (high precision instrument) just blend them into the casting with a fine stone until you can't feel it. Especially careful of lower surface of valve-side lever. Any sign of relieving, machining for spring or retainer OD? If you're really nervous, cryo treatment may make you feel better. Yes, I'd run them.
Boffin Emeritus
[Re: viperblue72]
#2590100
12/10/18 10:14 PM
12/10/18 10:14 PM
madscientist
Washington
Whatever I run will be a street type roller. I wasn’t so much worried about durability of the rocker, but wear and tear on the guides and valve tips etc. The last street roller I ran was 200 seat pressure and 560 open, although it probably never saw 560 with only .580 lift. If the geometry is correct, the guides won't wear out. That rocker is highly underrated. To you have the econo head or the are you using offset blocks and shafts?
[Re: viperblue72]
#2590170
12/11/18 01:03 AM
12/11/18 01:03 AM
Posts: 43,097 Bend,OR USA
Many,many , many SS Mopar racers used them for years and years. I'm sure there a decent piece to start with for the W2 so I wouldn't hesitate at all on using them John Dieanna used them on his old M.P and later Comp Eliminator W2 motors, he let the clutch out at 8200 and shifted it around 8800 RPM As far as I know he never broke one either
[Re: madscientist]
#2590204
12/11/18 02:09 AM
12/11/18 02:09 AM
Posts: 2,141 junction city oregon
viperblue72
Whatever I run will be a street type roller. I wasn’t so much worried about durability of the rocker, but wear and tear on the guides and valve tips etc. The last street roller I ran was 200 seat pressure and 560 open, although it probably never saw 560 with only .580 lift. If the geometry is correct, the guides won't wear out. That rocker is highly underrated. To you have the econo head or the are you using offset blocks and shafts? These are the w2 race head.
[Re: viperblue72]
#2590247
12/11/18 05:11 AM
12/11/18 05:11 AM
madscientist
Washington
Whatever I run will be a street type roller. I wasn’t so much worried about durability of the rocker, but wear and tear on the guides and valve tips etc. The last street roller I ran was 200 seat pressure and 560 open, although it probably never saw 560 with only .580 lift. If the geometry is correct, the guides won't wear out. That rocker is highly underrated. To you have the econo head or the are you using offset blocks and shafts? These are the w2 race head. Then you should have offset stands and shafts. Make sure the stem height is correct. Then you adjust the stand height to correct the geometry. If you get that right, those rockers are good to at least 8800 RPM with the spring loads I posted earlier.
