Re: Best 440 intake w/dominator carb
[Re: dafixr]
#2589867
12/10/18 03:24 PM
12/10/18 03:24 PM
Posts: 43,097 Bend,OR USA
What is the best intake for a 499 big block stroker race only with a 1150 dominator
or can we use the adapator to use our 4150 manifold now
Thanks It depends on which size ports on which intake will work the best, I have change the bolt pattern size to fit Dominator carbs. on more than one intake, the last one was a Indy dual 4500 tunnel ram that I wanted to run a set of 4150 type throttle body with them in line for the linkage On your deal make sure that the throttle blades will clear the intake manifold once you mount the carb by changing the bolt pattern
[Re: dafixr]
#2589874
12/10/18 03:30 PM
12/10/18 03:30 PM
Posts: 30,989 Oregon
AndyF
Thanks Not sure what you mean by best so you'll have to clarify that a bit. I assume you mean the best that you can afford so that most likely means something like a Super Victor or Indy 440-3. Personally I like the Super Victor better than the Indy stuff. If you really want a good intake then you need to send it to someone like Wilson Manifolds for their porting magic. Once you do that then you'll have a good intake.
[Re: dafixr]
#2589910
12/10/18 05:00 PM
12/10/18 05:00 PM
Posts: 21,064 Niles , Ohio
therocks
Niles , Ohio
Old school but I run the MP M1 intake on my 440.Its street driven with the 1050 Dominator.Runs great and even is decent on the street for being so radical.Rocky
Chrysler Firepower
[Re: dafixr]
#2589951
12/10/18 06:14 PM
12/10/18 06:14 PM
AndyF
the intake is a victor and eledbrock alum heads that we have on it now not sure which heads carb is 950 quick fuel we are planning to change cam, convertor and carb for next season. I will check to nite.
Ok, that raises another question. Do you have standard port heads or MW port heads? If you have standard port heads then the Indy stuff won't fit. You might be able to find a Mopar M1 4500 intake. They work pretty well and are usually fairly inexpensive since they aren't super popular.
[Re: dafixr]
#2589955
12/10/18 06:20 PM
12/10/18 06:20 PM
The Super Victor is available with std ports for the RB block.
[Re: dafixr]
#2590065
12/10/18 09:25 PM
12/10/18 09:25 PM
Posts: 11,996 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The 4150 manifold is easy to convert to the 4500.
1) screw aluminum bolts into the bolt holes 2) cut them off flush 3) drill and tap the new 4500 pattern 4) open up the plenum to clear the 4500
I am not suggesting that the 4150 manifolds are better than the 4500 manifolds. Just a heads up on how easy it is to convert one. One of my favorite manifolds was a Holley Street Dominator that I converted that way. Worked real good and fit under the hood.
Master, again and still
[Re: fast68plymouth]
#2590077
12/10/18 09:39 PM
12/10/18 09:39 PM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
The Super Victor is available with std ports for the RB block. The Super Vic intakes are both the same casting imo,you can open the standard to max wedge . Plenty of meat there . That is what i did when going stockish to max wedge . When fitting to non raised stock port i did have to cut a little top and bottom of intake face for clearance Tex
