727 case restoration #2585574
12/01/18 11:01 AM
12/01/18 11:01 AM
S.W. Florida
blkbee6pack Offline OP
S.W. Florida
I am ready to rebuild and restore my 727 what is every one doing to make the case and tail look new? Or is there a link to go to if this has been talked about before? THANKS MOPARTS
Re: 727 case restoration [Re: blkbee6pack] #2585873
12/01/18 11:12 PM
12/01/18 11:12 PM
Greenwood Lake, NY
fuelishnsilly Offline
Greenwood Lake, NY
Have you tried brushing Naval Jelly on it? It cleans aluminum up really, really well and will leave it looking nice and fresh cast. Then you could apply some RPM to it to seal up the pores so it doesn't oxidize.
inherited a 69 roadrunner from my grand pop.
Re: 727 case restoration [Re: blkbee6pack] #2587711
12/05/18 07:51 PM
12/05/18 07:51 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Bead Blast it and shoot it with as cast Aluim Spray.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: 727 case restoration [Re: blkbee6pack] #2587883
12/06/18 01:46 AM
12/06/18 01:46 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
NNNOOOO! Don't paint it. Completely wrong look.
Re: 727 case restoration [Re: blkbee6pack] #2589683
12/10/18 01:09 AM
12/10/18 01:09 AM
North Carolina
469runner Offline
469runner  Offline
North Carolina
If not painted it will quickly oxidize and look terrible. I guess that is the correct look. LOL. I bead blasted mine and painted with Eastwoods Aluma Blast paint. Still looks good many years later.
Re: 727 case restoration [Re: blkbee6pack] #2589806
12/10/18 01:47 PM
12/10/18 01:47 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
I used a combination of Eastwood's Alumablast and their Titanium spray. To me the Alumablast is too intense silvery. The Titanium paint is slightly deeper silver. Doing a light coat over a wet coat of Alumablast gave to me the closest match to natural cast aluminum that has been sitting exposed.
Re: 727 case restoration [Re: blkbee6pack] #2589815
12/10/18 02:02 PM
12/10/18 02:02 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Or you can simply clean it as best you can (method of choice) and protect it with Gibbs Lubricant. This eliminates the paint for a more natural look
Re: 727 case restoration [Re: blkbee6pack] #2589865
12/10/18 03:21 PM
12/10/18 03:21 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i media blast for a living, couple years ago i bought a vapor blast cabinet that works well for aluminum. i have done a few transmissions with good results. its slightly brighter than OE but will fade over time. The finished surface is not open like a fractured abrasive will do so it will not oxidize over time. Not saying this is the best way as the keyboard experts will chime in that is some how wrong but one option for you if you have anyone local to you with a set up. You can google or you tube search for examples
Re: 727 case restoration [Re: chrisf] #2590267
12/11/18 09:17 AM
12/11/18 09:17 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Originally Posted By chrisf
. . . i bought a vapor blast cabinet that works well for aluminum. i have done a few transmissions with good results. its slightly brighter than OE but will fade over time. The finished surface is not open like a fractured abrasive will do so it will not oxidize over time. Not saying this is the best way as the keyboard experts will chime in that is some how wrong but one option for you if you have anyone local to you with a set up
I’m completely behind you and agree the process produces outstanding results. I’d have done this if I could have found a local with a cabinet large enough. Even looked into buying a cabinet but found these are wildly expensive vs a traditional blast box.
The only other thing to consider is that before blasting the case the trans needs to be stripped, where cleaning and protecting can be easily accomplished without gutting the trans.
