Re: 904 frictions
[Re: hysteric]
#2577679
11/12/18 11:07 PM
11/12/18 11:07 PM
I'm thinking there is a thickness difference & I saved an article in the Jan 1999 "high performance mopar" magazine regarding using thinner frictions to use 6 clutches in a 5 clutch 3rd speed (their words) drum from a 75-79 360 eng. 10 second drag raced 904 based '66 valiant. I have one to do & I am going to Google it.
Re: 904 frictions
[Re: hysteric]
#2577688
11/12/18 11:14 PM
11/12/18 11:14 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
I use 5 thin ones from the rear in the front to get 5 disc instead of 4...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: 904 frictions
[Re: hysteric]
#2577750
11/13/18 12:52 AM
11/13/18 12:52 AM
Posts: 11,526 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
OEM the rears were more aggressive and smooth since it's not a shift element. Fronts are waffle or grooved for the fluid to escape on apply. Now you can get about any configuration. A good performance material or the blues. I use rears (.063) in both to get 5 in the front. You may have to juggle steels and maybe trim the pressure plate to dial in the clearance.
Re: 904 frictions
[Re: hysteric]
#2577815
11/13/18 04:24 AM
11/13/18 04:24 AM
what clearance(s) should a person shoot for (front/rear)?
Re: 904 frictions
[Re: hysteric]
#2577827
11/13/18 07:38 AM
11/13/18 07:38 AM
Posts: 6,136 Melbourne , Australia
LA360
The blues are 2 x the price of the Alto reds. Any benefit in using the blues over the alto's? Not that I've heard, at your power level a standard style friction material will hold up. Getting the clearance right is the important part I was always told.
Alan Jones
Re: 904 frictions
[Re: LA360]
#2577839
11/13/18 10:20 AM
11/13/18 10:20 AM
Posts: 117 Aus
hysteric
Aus
The blues are 2 x the price of the Alto reds. Any benefit in using the blues over the alto's? Not that I've heard, at your power level a standard style friction material will hold up. Getting the clearance right is the important part I was always told. Raises a good question. How much power can standard frictions take in a 904?
Re: 904 frictions
[Re: dvw]
#2577891
11/13/18 01:16 PM
11/13/18 01:16 PM
Doug thank you (& noted!)
Re: 904 frictions
[Re: dvw]
#2577928
11/13/18 02:32 PM
11/13/18 02:32 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The 1st Pro trans I ever serviced had the standard silver rear frictions run in the front location. 727 with 904 guts. Doug How long ago was that? That was an old trick before the blues, Altos, etc. were available, since the rear frictions were typically more aggressive. Any serious unit I've seen, (Stock/Super Stock, low line pressure, high horsepower) has had, or I used, blues, front and rear, along with Kolene steels. I keep the rear clutch clearance snug, maybe .025. Front, depending on trans brake or not, 010 to 012 per friction.
Re: 904 frictions
[Re: CMcAllister]
#2578040
11/13/18 07:17 PM
11/13/18 07:17 PM
Front, depending on trans brake or not, 010 to 012 per friction. Is that .010-.012 with or without a trans brake?
