Re: A body suspension recipe
[Re: maxwedge1]
#2577470
11/12/18 01:31 PM
11/12/18 01:31 PM
maybe take it to a frame specialty shop & get the subframes checked/straightened. there's the Moog "offset" UCA bushings meant to sideways kickout for more camber & you turn one around before pressing it in to get more positive caster. On the rear suspension I am out on a limb but just me if getting 1 or 2" over is a good plan I would get the 2" more arched ones & you can lower it later if needed. I wondering if the jacked up back is contributing to this but if the tires are huge then either that or fender mods and or wheel offset/pad perch relocating.
[Re: maxwedge1]
#2577479
11/12/18 01:49 PM
11/12/18 01:49 PM
Posts: 14,889 up yours
Supercuda
The jacked up look is definitely contributing. Whether that is the entire problem, I do not know.
[Re: maxwedge1]
#2577495
11/12/18 02:32 PM
11/12/18 02:32 PM
Posts: 27,453 So Cal
autoxcuda
So Cal
Fully adjustable UCA: https://www.jegs.com/i/Specialty-Product...UxoCc9sQAvD_BwEIf the aftermarket UCA that was built correctly to give you more caster couldn't get you close, you’re going to need a lot of trial and error. It must be pretty far off. Don’t know how friendly you are with you alignment guy. But I talk with him before you take the car with fully adjustable arms. Try to get an idea what he is going to charge you. You might run up a steep alignment labor bill. For $300 you can buy a nice home alignment tool.
[Re: krautrock]
#2577740
11/13/18 12:36 AM
11/13/18 12:36 AM
Posts: 20,478 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Why not take it to a frame shop and have them measure up what you have and pull it square again if it's off a little? Not much money in the big picture and the car will be better for it. Hardest part is getting the frame specs for something that old.
I once took an old Mustang coupe to the dealership I worked at in the late 90's to have the alignment verified right after I got it back together and was also told that it would not adjust to his exact book specs. I have heard more than once about techs not being able to align old cars very well. Not sure why that is????
[Re: maxwedge1]
#2578308
11/14/18 12:07 PM
11/14/18 12:07 PM
Posts: 12,005 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The height of the rear will affect the front alignment. So, decide on your final height before you do anything with the front.
You absolutely have to find an alignment guy that is familiar with our old Mopars. That is very important.
I have had several Mopars aligned that to get them to drive straight, some of the specs ended up "in the red". That's what it took to get them to drive straight and there were no down sides.
If it were me, I'ld get a starting point on the alignment. Set your rear height where you want it to end up, then take it to the shop and have your front end specs measured where they are now. Maybe even have him see if it will come in as it is now.
That way you know how much additional adjustment you might need. The offset bushings may well do it by themselves. For most of us street guys, I have always felt that the adjustable uppers was money wasted. If the car needs more than the offsets offer, I have 1/4" or so cut out of the rear UCA.
One last thought; I have often struggled with getting the rear height just right. And then you have the possibility of it settling down over time after I get the height I liked. So I have went to using leaf helper springs from Helwig that I mount on top of the rear segment.
They stiffen the rear some, are not visible, and I can adjust it up and down exactly like I want any time I want. And at the drag strip, I can still pull 1.5 60 foots. What's not to like?
Master, again and still
