shorter roller rockers needed #2576986
11/11/18 01:27 AM
11/11/18 01:27 AM
RapidRobert Offline OP
I have some 1.6 rockers going onto my EQ heads (not sure if furd or chebby). the roller is almost at the outer (ex side) edge of the valve stem. Are there offset rockers with a shorter fulcrum distance on that side? Not sure what this will do to the ratio & I am just thinking out loud right now to see IF anything is available to correct this (& I may just have to live with it & see how the valve tips look after the first race) but it dont hurt to inquire.
Re: shorter roller rockers needed [Re: RapidRobert] #2576995
11/11/18 02:15 AM
11/11/18 02:15 AM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
Crower and Harland Sharp have rockers that fit that app. I have a used Crower I could send you for to trial fit.
Re: shorter roller rockers needed [Re: J. Hammer] #2576999
11/11/18 02:26 AM
11/11/18 02:26 AM
Bro I will send you a PM
