Bleeding Strange front Disc Brakes #2576303
11/09/18 01:06 PM
11/09/18 01:06 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I just did a front disc bra kik e swap and see there are 4 blenders on the calipers.
2 top and 2 bottom.
1st do I need to to uh ch te back brake calipers or can I just bleed the fronts?
2nd. Is it necessary to bleed all 4 blenders and I be li I've I have to start at the top.
So far I bled just the 1 top and 1 bottom outer blenders and still cant get a pedal.
Re: Bleeding Strange front Disc Brakes [Re: Sammy] #2576311
11/09/18 01:17 PM
11/09/18 01:17 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
It's good practice to bleed all four calipers whenever the system has been opened up.
You only need to bleed the top screw on each side of the caliper. Start with the right rear outer, then the right rear inner, then the left rear outer, then the left rear inner, then the right front outer, then the right front inner, then the left front outer, then the left front inner.
[img]http://i.imgur.com/boeexFms.jpg[/img]
31 Plymouth Coupe, 392 Hemi, T56 magnum
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
I don't regret the things I've done. I only regret the things I didn't do.
"Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Bleeding Strange front Disc Brakes [Re: Sammy] #2576314
11/09/18 01:19 PM
11/09/18 01:19 PM
pittsburghracer Offline
Sammy you may not end up doing it but I ended up buying a pressure bleeder from Summit to get my Strange brakes bleed right. Man that thing worked great.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Bleeding Strange front Disc Brakes [Re: pittsburghracer] #2576342
11/09/18 02:14 PM
11/09/18 02:14 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Got a link to that pressure bleeder.
Why us it better than gravity bleeding?
Re: Bleeding Strange front Disc Brakes [Re: Hemi_Joel] #2576345
11/09/18 02:16 PM
11/09/18 02:16 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Thanks even though I never touched the rear system?
Re: Bleeding Strange front Disc Brakes [Re: Sammy] #2576348
11/09/18 02:22 PM
11/09/18 02:22 PM
Don't ask me but I tried everything even thinking it must be the master cylinder so I bought and installed a new one. I bought the motive kit. You can call and buy the kit for your set-up or buy the universal one so you are set up for all your cars.
https://www.summitracing.com/search/depa...and-accessories
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Bleeding Strange front Disc Brakes [Re: Sammy] #2576435
11/09/18 04:47 PM
11/09/18 04:47 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Only use the bleed screws at the top. Calipers with screws on both sides and done like that so they can be mounted either direction. Rears should only need to be bled if they got air in them at the master, but if they've been together for a while, I'd bleed and flush them while I was there.
Re: Bleeding Strange front Disc Brakes [Re: CMcAllister] #2576456
11/09/18 05:30 PM
11/09/18 05:30 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
They are new in the box.
I pumped them up to try and get a pedal, from only the outer top first then bottom on the outside bleeders. Opened up the reservoir cap and bubbles were flying around in there.
Re: Bleeding Strange front Disc Brakes [Re: Sammy] #2576476
11/09/18 05:58 PM
11/09/18 05:58 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Air rises to the top. Bleed from the both tops only. Don't pump it. You just aerate the fluid and make it impossible to bleed until you leave it set awhile.
Re: Bleeding Strange front Disc Brakes [Re: pittsburghracer] #2576492
11/09/18 06:42 PM
11/09/18 06:42 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Hey, will this one work for the dual mopar master cylinder? I can live with this price tag.
https://www.summitracing.com/parts/mvp-0103/applications/?ibanner=SREPD2
Re: Bleeding Strange front Disc Brakes [Re: Sammy] #2576526
11/09/18 07:57 PM
11/09/18 07:57 PM
Your best bet would be to call them and tell them what master cylinder you have.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
