Re: CalTracs setup - Chassis separation or limit it?
[Re: WHITEDART]
#2578059
11/13/18 07:52 PM
11/13/18 07:52 PM
Posts: 4,662 On the parachute mount
n20mstr
your comparing apples to oranges Understood. But I wasn't sure how much of this was because a radial tire works better w/ the chassis tuned differently than a bias-ply, or because of all those other variables like HP, etc. .. correct me if I'm wrong but aren't most stalkers running a radial now.. I think the original reason for the Post was just to show that cars can hook and go fast without pulling the front wheels off the ground.. we hit our car with everything that we can on the starting line. . it has been quite the adventure getting the car to work without all the rotation.. I myself have asked many questions on this forum regarding.. rotations.. I have found the most important thing is controlling the rear end of the car.. if it separates too quickly it will Top out and unload the tire.. if it's too slow it will never hook.. has kind of been a science project of mine on my car.. ? stalker? if that's directed towards me, I think not 5.10 @ 140 on a 275, no wheelstand. I think im qualified to comment, and yea your correct about controlling the rear. Smash the tire and hold it there. If I give Brad a hard time....he knows where im coming from. reading is fundamental....you meant "stocker" not "stalker"....I guess I should read more..LMAO ! ! !
....BAD A$$ STREET CAR.....
[Re: BradH]
#2578092
11/13/18 09:10 PM
11/13/18 09:10 PM
Posts: 14,478 So. Burlington, Vt.
I’d say...... about this much seems to work pretty good:
[Re: BradH]
#2580220
11/19/18 03:09 PM
11/19/18 03:09 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
The goal is to get to 100% Anti-Squat. This means trying to keep the rear wheel neutral during the launch. If you have a light big power car you need to control the front end lift with wheelie bars. Pro Stock, Pro Mod ect...
Every guy that runs in the NHRA Stock class has there car figured out to the umth degree. The rest of us are trying to learn as we go to get our combos figured out to be the quickest we can be.
My experience has shown me that I'm still very far away from knowing everything.
A couple of guys on here have impressed me though the years and I don't take there advice lightly.
White Dart (Shiloh)
Al Alguire
W5Dart66 (Brett)
Best of luck guys and keep us in the loop on how to improve.
[Re: fast68plymouth]
#2580221
11/19/18 03:17 PM
11/19/18 03:17 PM
hemi-itis
I’d say...... about this much seems to work pretty good: Could you post a side shot at rest so we can see the amount of rise please?
[Re: DoubleD]
#2580222
11/19/18 03:21 PM
11/19/18 03:21 PM
hemi-itis
Yep just a little will do ya! Same for you,picture at rest I'm still chasing the carbs,car leaves straight 85% of the time so I have not tried different settings and preload. Does more preload help if the it's going straight off the line?
[Re: Biginchmopar]
#2580317
11/19/18 08:13 PM
11/19/18 08:13 PM
Posts: 9,791 MI, usa
dvw
MI, usa
White Dart (Shiloh)
Al Alguire
W5Dart66 (Brett)
How do achieve 100% anti-squat if the instant center is above the anti-squat line? A Cal-Track instant center is pretty short, most likely putting above the anti-squat line. You can slow it down with stiff rebound, but the physics says it'll still separate. Am I missing something? Doug
[Re: dvw]
#2580375
11/19/18 10:54 PM
11/19/18 10:54 PM
Biginchmopar
Carson City, Nevada
White Dart (Shiloh)
Al Alguire
W5Dart66 (Brett)
How do achieve 100% anti-squat if the instant center is above the anti-squat line? A Cal-Track instant center is pretty short, most likely putting above the anti-squat line. You can slow it down with stiff rebound, but the physics says it'll still separate. Am I missing something? Doug I said the goal is 100% Anti-Squat I didn't say it should be done with CalTracs You not missing anything, you have to control the separation with whatever you can, shocks, weight, front end travel, ect... Watch the World fastest leaf spring Mopar, it's a Dart that runs real hard and the I don't think it lifts the front tires off the ground. I'm saying if you work on it you are looking for 100% Anti-Squat.
[Re: dvw]
#2580382
11/19/18 11:16 PM
11/19/18 11:16 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Man thanks for the kind words those are some big names that you Tangled me up with . I have learned a lot from both Brett and AL Myself. . As ET improves the Suspension requirements change. I think the best thing is get the cars out there and get some video up so we can all take a look. And all learn from one another
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: Biginchmopar]
#2580405
11/19/18 11:52 PM
11/19/18 11:52 PM
dvw
MI, usa
White Dart (Shiloh)
Al Alguire
W5Dart66 (Brett)
How do achieve 100% anti-squat if the instant center is above the anti-squat line? A Cal-Track instant center is pretty short, most likely putting above the anti-squat line. You can slow it down with stiff rebound, but the physics says it'll still separate. Am I missing something? Doug I said the goal is 100% Anti-Squat I didn't say it should be done with CalTracs You not missing anything, you have to control the separation with whatever you can, shocks, weight, front end travel, ect... Watch the World fastest leaf spring Mopar, it's a Dart that runs real hard and the I don't think it lifts the front tires off the ground. I'm saying if you work on it you are looking for 100% Anti-Squat. Video's show Digby's Dart separating a good 4" or more at the rear. Mark Menscer made mention recently that instant center settings are getting shorter and higher to load the tire harder. As for the front being controlled with slow rise, I agree 100%. Depending on available tire hit the car may or may not need front travel. 2 opposite ends of the car. Most cars I've been involved with that don't work have rebound too loose on either front, rear, or both ends. Doug
