Re: Eicke pro stock head #4876254 [Re: 340KID] #2580600
11/20/18 01:21 PM
11/20/18 01:21 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I'm curious to know what you find as well.
The block PN dates to the early 2000's, which as we all know they were running the Hemi 99 stuff in NHRA PS by then. There was an IHRA 5" BS Hemi head available as well. While I have never personally seen one, I am inclined to believe that it's a cross between a Shotgun Head and a CHemi head based on what I have been told by others.
Regardless, I'm sure the stuff is more than capable of getting the job done. It's always interesting to see where the old Pro Stock stuff turns up. Hopefully there's not too much 'one-off' stuff inside...that could make things interesting.
Re: Eicke pro stock head #4876254 [Re: 340KID] #2580614
11/20/18 01:56 PM
11/20/18 01:56 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Did this engine happen to come in a Dart?
Re: Eicke pro stock head #4876254 [Re: Al_Alguire] #2580616
11/20/18 02:00 PM
11/20/18 02:00 PM
CT
3
340KID Offline OP
340KID  Offline OP
CT
no - a 1972 Challenger
Re: Eicke pro stock head #4876254 [Re: 340KID] #2886690
02/11/21 11:40 AM
02/11/21 11:40 AM
Wisconsin
O
Oregonjam Offline
Oregonjam  Offline
O
Wisconsin
340KID,
What did you find out on the motor?
All Merlin castings beginning with P are direct Chrysler checked out part numbers.
The block casting P5249533 is a Chrysler part number. There is so much material in this block they were very flexible in machining. It was supplied by Bill Mitchell and is likely a complete 1997 to 1999 Pro-stock Eicke motor. If so the bore spacing will be 4.9" and honed out to 499 CI. It is a Merlin based GM design but was used by Mopar and qualified as a ProStock Mopar motor based on cast in Chrysler part number. In the words of Bill Mitchell Jr, 'with a foundry and machining services, the teams could pretty much get anything they wanted'. The Merlin Part number is 080080S. Good luck finding any information on that or an original spec sheet. I'm not sure if they ever existed in public as the block was a very specific casting and heavily machined while being considered a Special Order. All the ones I know of were lightened by C&C valley profiling, side walls were profiled, they used Bryant Racing Billet Crank with a 3.625" stroke, and 4.9" bore spacing. There is a huge range in Merlin prices from $2500 to $10k. These were on on the high end at the time.
If you find a spec sheet or have any additional information please do share it.
Thanks,
John
Re: Eicke pro stock head #4876254 [Re: Oregonjam] #2887549
02/13/21 10:04 AM
02/13/21 10:04 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
They were Pontiac Symmetrical port pro stock heads with a Mopar part number. They used a Merlin block. Not Mopar at all.
Re: Eicke pro stock head #4876254 [Re: fbs63] #2887597
02/13/21 12:45 PM
02/13/21 12:45 PM
Wisconsin
O
Oregonjam Offline
Oregonjam  Offline
O
Wisconsin
Agreed. It’s mopar by part number on block only so it could bend around the rules.
