Re: Front brakes shoes not advancing - do I bend the arm..?
[Re: 67SATisfaction]
#2638514
03/29/19 03:12 PM
03/29/19 03:12 PM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Figured I'd share the final outcome for y'all to know....
I found basic rebuild kits online for $19.99 and used the one part I needed... you can see the shiny new cable guide here [EDIT: The photo absolutely refuses to load properly, sorry]... and a pic of how the old one wore out and slackened the cable so it stopped working..
Cheers, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: RapidRobert]
#2638659
03/29/19 10:54 PM
03/29/19 10:54 PM
67SATisfaction
Albany, NY
Yeah it was easy once I saw what the problem was... but dang I had to look real long and hard at it before I saw it .. Always remember to start looking at the simplest possible answer FIRST. - A
#2638662
03/29/19 11:00 PM
03/29/19 11:00 PM
That was driving you bonkers for quite awhile & I ain't never seen a guide plate do that ever.
#2638683
03/30/19 02:56 AM
03/30/19 02:56 AM
Posts: 43,115 Bend,OR USA
Yeah it was easy once I saw what the problem was... but dang I had to look real long and hard at it before I saw it .. Always remember to start looking at the simplest possible answer FIRST. - A From that lesson comes the old adage of KISS, Keep It Simple Silly or Stud, your choice on words used
