Callies Magnum XL Cranks
#2567500
10/21/18 10:28 PM
10/21/18 10:28 PM
Posts: 1,098 Massillon, Ohio
cudatom
Massillon, Ohio
Found a crank that I may be interested in. How would this rate compared to a Crower or some of the other better manufacturers. It will go into a big block I have ordered from Marsh Performance.
I have the serial number of the crank and will call Callies tomorrow but interested in what people's experience has been.
Ok
Re: Callies Magnum XL Cranks
[Re: hemi-itis]
#2567576
10/22/18 12:18 AM
10/22/18 12:18 AM
cudatom
Massillon, Ohio
Todd would NEVER steer you wrong! I agree. He has been great to deal with. The crank isn't from Todd though its a private party. Just hard to find much info on the crank. I will be talking w/callies and get some info.
Ok
[Re: sasquatch]
#2568564
10/23/18 08:58 PM
10/23/18 08:58 PM
cudatom
Massillon, Ohio
GOOD cranks, Have several well north of 1000 Hp going fine. Just check all the normal stuff, Cracking, evidence if heat, snout and crank bolt holes for thread damage," Todd Thanks Todd. Its new in the crate. Called Callies, 4.35 stroke, 2.20 rod journals w/bbc width, Chrysler snout, 6.80 or longer rod. The only thing I'm not a fan of is its a 6 bolt but I can work with that. Its been sitting a long time. I'm going to have the machine shop open it up and check everything out.
Ok
