Small block stroker kits? #2566761
10/20/18 01:38 AM
10/20/18 01:38 AM
junction city oregon
V
viperblue72 Offline OP
V
Does anybody make a stroker kit with a smaller journal?
I know Hughes has a 4.18 kit with smaller journals, but I’m not sure I want more than a 4” stroke. I’d like to run a smaller journal slightly longer rod.
My build will be a w2 pump gas street/strip for a mostly street 4 speed cuda.
Re: Small block stroker kits? [Re: viperblue72] #2566771
10/20/18 01:56 AM
10/20/18 01:56 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Molnar
Re: Small block stroker kits? [Re: viperblue72] #2566776
10/20/18 02:10 AM
10/20/18 02:10 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Bloomer Performance Engineering
Tony
70 AARCuda Vitamin C
71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield)
71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas)
71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: Small block stroker kits? [Re: 70AARcuda] #2566780
10/20/18 02:23 AM
10/20/18 02:23 AM
V
V
Molnar only lists standard journal for a 360. And I can’t find any info online about bloomer performance.
Re: Small block stroker kits? [Re: viperblue72] #2566811
10/20/18 04:08 AM
10/20/18 04:08 AM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Re: Small block stroker kits? [Re: viperblue72] #2566812
10/20/18 04:11 AM
10/20/18 04:11 AM
b1dartsport Offline
b1dartsport  Offline
Re: Small block stroker kits? [Re: viperblue72] #2566866
10/20/18 11:27 AM
10/20/18 11:27 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Read this article in "Best of Moparts".
430 Small Block Build
That's what convinced me to build my 428 using the Bloomer Performance Engineering kit with a 6.200 rod and 2.00 journal. Drops right in, all quality components, and the pistons are ordered to exactly what you need.
Ring pack, bore, compression.
Mine came out great, 5 years now, so much fun on the street.
8021758-DSC01591.jpg8022113-DSC01601.jpg15369007_817669805039642_8844590694082736413_o - Copy.jpg
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Small block stroker kits? [Re: viperblue72] #2566867
10/20/18 11:27 AM
10/20/18 11:27 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
What are the pros or cons of a smaller journal longer rod engine?
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Small block stroker kits? [Re: viperblue72] #2566920
10/20/18 02:11 PM
10/20/18 02:11 PM
AndyF Offline
AndyF  Offline
I did a 427 a few years back with a K1 crank and rods. That was a beast of an engine. Pushed a '68 Valiant to 160 mph on the road race course.
Re: Small block stroker kits? [Re: viperblue72] #2566935
10/20/18 03:00 PM
10/20/18 03:00 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My 434 is running a Bloomer 4.125" crank with 2.00" rod journals and a 6.200 rod also. Nice stuff IMO. My pistons are custom Diamond.
Re: Small block stroker kits? [Re: viperblue72] #2566990
10/20/18 05:28 PM
10/20/18 05:28 PM
V
V
Justinp61 thank you that’s a great article.
mopardude318, better clearance, better oiling, less rotating weight, less rod angle, lighter piston. Do I think any of that is critical in a street/strip deal? No, but if I can do it I might as well. There’s a reason people are choosing the 2.2 journal in big blocks over the old 2.375 I. Big blocks as well.
