1973 SB headers - truck vs van compatibility #2566489
10/19/18 02:44 PM
10/19/18 02:44 PM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Hi all - a guy near me is selling some old small block Thorley headers that he says are for dodge truck/van. I have a 73 truck.
When I google the Thorley headers, they had one part# for van and one for truck.
I can see one main difference in appearance, that the van headers (top picture), from the collector, come up at an angle, where the truck headers (second picture) seem to be straight for a longer stretch.
Van:
Truck:
The picture of the headers the guy is selling seem to match what the van headers look like. I see other mfgs like hedman also sell different versions between truck and van.
Does anyone know whether the van headers would fit on a truck, or generally what the difference is between van/truck headers for these years/engines? I'm concerned if the height/angle of the van headers will interfere with something on the truck. Thanks.
Re: 1973 SB headers - truck vs van compatibility [Re: Exit1965] #2568259
10/23/18 10:52 AM
10/23/18 10:52 AM
scratchnfotraction Offline
are you sure the tubes bend up?
they could be bent to the side.
a van engine sit a little off center in the chassis to make room for the foot controls. engine mounts are slightly different from trucks also.
I used a van/mounts in my truck and engine rubbed header on pass side frame rail. truck mounts centered headers in chassis with clearance on frame rail.
truck headers can be 2x only or 4x4 only or a 2x 4x4 combo. depends on what engine/trans combos along with chassis.
4x4 headers has piped moved to clear diff/shaft up front and most times the driver side is always the same but vary on tube placement and starter clearance. some only take the low torque starter or a mini starter.
in a van the front of engine is pushed to the pass side. so if you were to stand the header up right the bend is to line the exhaust collector inline with the chassis.
laying there in the pic it does look bent upward but I am sure it is a left right bend (more or less)
they should fit from the looks but could hang down lower in the chassis of a truck and may capture the starter = remove header to swap starter.
myself I use hedman truck hedaders.
79250 in the 88 440 truck = slips right in/tucks up in frame on bottom side
I have 2 SB sets
79080 2x only = slip right in/R&R starter without removing but low torque or mini only
79171 are 2x & 4x4 chassis = slip right in/R&R starter with out removing/#7 tube allows high torque(large) starter.
**this set also fit up to 93 with a NV4500 5 speed (which the 79080 #7 tube is in the way of fitting starter with NV4500 hydro bell)
found that info when I went to a NV4500 in my 85 truck with the 2x headers.
in the past it has been my experience that the van headers will fit the truck chassis but could have clearance issues pop up on install.
same as B/RB engine B-body headers in the truck chassis. yes the fit with trimming on frame rails and hang down below frame rails on bottom also captures starter making R&R suck.
in my best guess I would say they fit but may need to watch the shift linkage/torque rod and starter R&R. looks like they will hang down below frame which may free up the room you need for linkage/starter.
***another thing is clearance room...it does have a much thinner colletor with only 2 pipes merging which is good.
Re: 1973 SB headers - truck vs van compatibility [Re: Exit1965] #2568633
10/23/18 10:41 PM
10/23/18 10:41 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
What is the part number for the van headers sir?
Re: 1973 SB headers - truck vs van compatibility [Re: Exit1965] #2569021
10/24/18 06:20 PM
10/24/18 06:20 PM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Thanks Scratchn. I don't think I'll roll the dice on the headers with those potential differences.
mgoblue: Doug Thorley van headers were 106Y
Re: 1973 SB headers - truck vs van compatibility [Re: Exit1965] #2573715
11/04/18 01:31 AM
11/04/18 01:31 AM
n.c.
geo. Offline
geo.  Offline
n.c.
if your '73 is a 100 series, I think you'll have a little more room at the frame on the drivers side.
I think the 200-300 frame is wider on top which may rub on the tubes.
