6.1L crank pilot issue #2565060
10/16/18 08:46 PM
10/16/18 08:46 PM
Madison, Wisconsin
chrisnben Offline OP
Madison, Wisconsin
So- just acquired this 6.1L and someone has been in here- Am I screwed or what?? What's the chunk missing? Any suggestions? Thanks!
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
Re: 6.1L crank pilot issue [Re: chrisnben] #2565246
10/17/18 09:18 AM
10/17/18 09:18 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Using an automatic transmission will be fine, stick it will need to be repaired or use a pilot bearing that fits in the converter pilot.
Re: 6.1L crank pilot issue [Re: chrisnben] #2565260
10/17/18 10:24 AM
10/17/18 10:24 AM
Madison, Wisconsin
Madison, Wisconsin
it appears they broke off a piece trying to get the pilot bushing out?
Re: 6.1L crank pilot issue [Re: chrisnben] #2565323
10/17/18 12:59 PM
10/17/18 12:59 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Most likely. I don't know how else it would happen. Some real hammer mechanic's out there!
Re: 6.1L crank pilot issue [Re: fbs63] #2570911
10/29/18 11:37 AM
10/29/18 11:37 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
That will come out no problem. Being that you are from WI extracting broken stuff should be second nature. I'm a local hero around here lol.
I'd stand it on the front (gracefully) and use a long shank 1/8" carbide and grind on it until you can a) break it in pieces or b) find a broken tap extractor and try to get two prongs around what ever is in there.
Be patient and work with lots of light, you'll be good to go.
If none of that sounds good take it to a machine shop someone will gladly remove that for a hundo.
