Rear disc brake weight loss #2565035
10/16/18 07:55 PM
10/16/18 07:55 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
Does anybody know the weight savings for swapping to a rear disc brake kit over a stock drum brake setup? I'm looking at a wilwood dynalite kit for my new rear axle.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Rear disc brake weight loss [Re: 73cuda340] #2565104
10/16/18 10:13 PM
10/16/18 10:13 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I went from 11 X 2" to a Wilwood with the Explorer type internal parking brake and lost 16 pounds.
Re: Rear disc brake weight loss [Re: 73cuda340] #2565330
10/17/18 01:12 PM
10/17/18 01:12 PM
GA
roadrunninMark Offline
GA
Mopar Action did a two part article in the previous 2 magazines (not the one that just came out) where they swapped new Jeep rear disc setup. I think they lost about 25 pounds.
Re: Rear disc brake weight loss [Re: 73cuda340] #2565579
10/17/18 08:46 PM
10/17/18 08:46 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The stock 10" drums weigh about 36 pounds complete.
What is the shipping weight of the aftermarket stuff ?
Re: Rear disc brake weight loss [Re: justinp61] #2566860
10/20/18 11:09 AM
10/20/18 11:09 AM
clarks summit pa
clarks summit pa
Did you use the street or drag setup on these? The rotors are a lot thinner on the darg kits.
Re: Rear disc brake weight loss [Re: 73cuda340] #2566915
10/20/18 02:02 PM
10/20/18 02:02 PM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
When I did the BAER iron sport rear on the Bee ,similar to DR diffs 11.7" kit. I measured 16 lbs each side weight loss , 35 lbs 11x2.5 drums to 19 lbs disk.
Re: Rear disc brake weight loss [Re: 73cuda340] #2566938
10/20/18 03:08 PM
10/20/18 03:08 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
It's the street kit, the race brakes I looked at didn't have the parking brake and are much lighter.
