ATI Harmonic Balancer (keyway question) #2564518
10/15/18 06:10 PM
10/15/18 06:10 PM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
The hub has a 3/16 key way, The crank has a 3/16 & 1/4 inch keyways, Broach the hub to 1/4 key or just run the 3/16 and not worry about it?
Re: ATI Harmonic Balancer (keyway question) [Re: RATTRAP] #2564522
10/15/18 06:16 PM
10/15/18 06:16 PM
pittsburghracer Offline
I had to get a 1/4 to 3/16 key from Summit. ATI offers it but Summit has it.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: ATI Harmonic Balancer (keyway question) [Re: RATTRAP] #2564596
10/15/18 09:23 PM
10/15/18 09:23 PM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
I have the choice as the crank has opposing keys, 3/16 & 1/4, I just have it in my head that the 1/4 key is stronger. I may have the hub broached to 1/4.
Re: ATI Harmonic Balancer (keyway question) [Re: RATTRAP] #2564634
10/15/18 10:58 PM
10/15/18 10:58 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Is this a blower application? If so, broach the hub. If not, run the single. The correct key slot to use in a single application is the one that lines up to the #1 cylinder rod journal.
#1 tdc, the key should be aimed at the #1 deck. This will assure balancer marks in the correct position to use OE timing mark location.
Re: ATI Harmonic Balancer (keyway question) [Re: RATTRAP] #2564729
10/16/18 07:01 AM
10/16/18 07:01 AM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
Thanks for the insight as to why there is two key-ways in the crank, I will run as is, So bigger is not always better,lol
Re: ATI Harmonic Balancer (keyway question) [Re: RATTRAP] #2565216
10/17/18 02:47 AM
10/17/18 02:47 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Here's something I read on a Ford forum, found through googling, when I was concerned about crank keyway when putting my engine (non blown) together. It gave me reassurance that the key didn't really matter!
We used to experience these types of failures years ago on Chevrolet small blocks when we would use GMC blowers on the engine. The solution at that time ended up to be using a Chrysler sized snout (1.530" Dia) on the chevy cranks. The solution usually came with a double keyway. The double keyway existed because those of us with the Chryslers wanted quick and easy way to remove our lower blower drive hubs. To effect the easy removal we would hone the ID of the hub to have a very light press fit on the crank snout. We would also use double keys but our keys were 1/4" hardened or for those of us with access to it, tool steel. Our lower blower drive hubs were made out of premium billet steel material so we had a lot of strength to start with.
The final touch was the fact that Chrysler used a 3/4 x 16 snout bolt that, in grade 8 form, reached proper bolt stretch at 380 ft/lbs of torque. Very few of us (that I knew) ever went that high. But and here is the important point, at anywhere between 150 and 200 ft/lbs of torque nothing but nothing moved. The clamp load was phenomenal and it was the friction from the clamping load that actually secured everything on the front of the crank.
https://www.modularfords.com/threads/184...r-balancer-here
