Question on hot wire for electric choke #2564082
10/14/18 09:50 PM
10/14/18 09:50 PM
MD
75dusted Offline OP
75dusted  Offline OP
MD
Have a 73 Roadrunner with 440 motor, now running a carb with electric choke, where exactly is the best place to tap off of for 12 volt hot wire for the electric choke
Re: Question on hot wire for electric choke [Re: 75dusted] #2564089
10/14/18 09:57 PM
10/14/18 09:57 PM
RapidRobert Offline
RapidRobert  Offline
the blue ign1 wire running alongside the pass valve cover going to the alt field. You would want minimal voltage drops everywhere in that circuit.
Re: Question on hot wire for electric choke [Re: RapidRobert] #2564253
10/15/18 05:11 AM
10/15/18 05:11 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
And thats what factory did. On a 73 in fact, the provision already exist on harness, with a female packard terminal/plug floating around
