slant six carb not get gettin fuel to carb #2563651
10/14/18 12:16 AM
10/14/18 12:16 AM
las vegas,nv
mopar muscle7271 Offline OP
las vegas,nv
My buddy has a 68 plymouth satellite with slant six.just put a new fuel pump on and drained tank out.cant get fuel goin to carburetor at all when turnin the car over to start.any ideas why still?
Re: slant six carb not get gettin fuel to carb [Re: mopar muscle7271] #2563663
10/14/18 12:27 AM
10/14/18 12:27 AM
Supercuda Offline
Supercuda  Offline
One of the rubber lines on the supply side of the pump is sucking air.
Don't be the exception.
Re: slant six carb not get gettin fuel to carb [Re: mopar muscle7271] #2563690
10/14/18 01:08 AM
10/14/18 01:08 AM
RapidRobert Offline
RapidRobert  Offline
take the line off at the carb & fill the bowl at that fitting then hook the line back & & start it & see if it keeps going. Repeat 2 or 3 times. If no go after that then what Supercuda said, work upstream from the pump toward the tank to find the porosity/hole/issue.
Re: slant six carb not get gettin fuel to carb [Re: mopar muscle7271] #2563726
10/14/18 02:36 AM
10/14/18 02:36 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
remove gas cap at tank ,
unhook line going into pump ,
blow 25-40 lb air pressure through line.
use an elect pump to flush / draw fuel from line.
no leaks then reconnect and fuel should flow .
Re: slant six carb not get gettin fuel to carb [Re: Supercuda] #2563736
10/14/18 04:45 AM
10/14/18 04:45 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Or the steel line has a rust pin hole somewhere.
Re: slant six carb not get gettin fuel to carb [Re: Challenger 1] #2563765
10/14/18 10:21 AM
10/14/18 10:21 AM
Supercuda Offline
Supercuda  Offline
I tend to forget rust, don't have much of that around here.
Re: slant six carb not get gettin fuel to carb [Re: mopar muscle7271] #2563987
10/14/18 06:19 PM
10/14/18 06:19 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Started my 6 with a gas can, connected the hose to the tank side of the fuel pump. .do you have a clear fuel filter bet the pump and carb?to see if the pump is working..
Re: slant six carb not get gettin fuel to carb [Re: AARCONV] #2564085
10/14/18 09:54 PM
10/14/18 09:54 PM
RapidRobert Offline
RapidRobert  Offline
^^^ good point, this easily elims everything rearward from the pump & will likely simplify diagnosing. If three bowl primings wont take care of it then this is what I would do.
Re: slant six carb not get gettin fuel to carb [Re: mopar muscle7271] #2564152
10/14/18 11:18 PM
10/14/18 11:18 PM
Looking for a way out of Middl...
IMGTX Offline
IMGTX  Offline
How long has it been sitting?
I have had cars sit for a long time and the varnish from evaporating fuel clogged the line/inlet/sock.
There are several backwoods ways to check for clogs/bad pumps.
1. Use compressed air to either blow back through the line or into the tank and see if the air makes it through the line to the other side. Not too much pressure required.
2. If the tank has a good bit of gas in it, and you raise the back of the car with a jack it should flow out the line in the front from gravity. That works for most cars.
3. Do you have an electric pump? I use one to transfer fuel and start up cars with suspect fuel systems so I keep a spare set up for it on the shelf. Connect the electric pump in place of the factory one. If it starts the problem may be a bad fuel pump or flat cam lobe.
4. Hook the mechanical pump to a gas can with a fuel line in it to test the mechanical pump.
hope it helps.
Re: slant six carb not get gettin fuel to carb [Re: mopar muscle7271] #2566024
10/18/18 05:02 PM
10/18/18 05:02 PM
las vegas,nv
las vegas,nv
Thanks for the replys used a manual siphon pump hooked up one the hoses off pump to gas line then slowly pump it.gas was comin through line.then hook up the car gas hose back to line.it started pickin up to carb.also put alittle more gas in as well.
