School me on BB topside oiling
#2562676
10/11/18 11:47 PM
10/11/18 11:47 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I’m looking at moving to a new set of rockers to add some ratio / lift to make better use of my heads. My current rockers are bronze bushed units, I’m looking at a set of needle-bearing roller rockers. My assumption is that this change at the shaft would release a ton of oil pressure. (Correct??). Do I need to install a restricter somewhere? Walk me through this please.
Engine currently idles around 45psi and runs at 70psi, 80 at higher RPMs.
Thanks-
Re: School me on BB topside oiling
[Re: StealthWedge67]
#2562684
10/12/18 12:02 AM
10/12/18 12:02 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
If you have Indy heads you can restrict the oil at the rear oil line feeds they have, if not Im not sure. I am not a fan of needle roller rockers as I have had one fail putting needle bearings through my engine, one found its way to the oil pump which stopped the pump, snapped the drive and the engine kept running
1963 Plymouth Max Wedge 1971 Barracuda
#2562711
10/12/18 12:33 AM
10/12/18 12:33 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Assuming a stock oiling system, you should have no problems. That being said.... If someone has altered the #4 cam journal or bearing with a groove, (common practice that I am strongly against) you best have some sort of restrictor in the supply drilling from the cam to the deck surface. With a grooved #4 cam journal, and no restrictors, you WILL lose about 60% of the oil to #4 main, and #6 rods. Even if you didn’t intentionally alter the oiling, some cam companies alter the journal to save valve train parts (at the cost of the bottom end) There are better ways to get oil up top. Hopefully you have a stock oiling sytem. The stock oiling sends oil in pulses up top.
#2562720
10/12/18 12:57 AM
10/12/18 12:57 AM
Posts: 20,145 PA.
pittsburghracer
CNC’d Stealth heads. Stock oiling. I did this to my Sons car this year and its working out great with Harlan Sharp rockers on Edelbrock heads. It a small block but the same idea could be used. I tapped the rocker shaft oiling hole on both heads and screwed a brass set screw in with a .060 hole in it. That way if I wanted more or less oil I could simply remove the rocker shaft and go bigger or smaller. I bought a bag a brass set screws off ebay.
[Re: pittsburghracer]
#2562741
10/12/18 01:44 AM
10/12/18 01:44 AM
ozymaxwedge
Australia
CNC’d Stealth heads. Stock oiling. I did this to my Sons car this year and its working out great with Harlan Sharp rockers on Edelbrock heads. It a small block but the same idea could be used. I tapped the rocker shaft oiling hole on both heads and screwed a brass set screw in with a .060 hole in it. That way if I wanted more or less oil I could simply remove the rocker shaft and go bigger or smaller. I bought a bag a brass set screws off ebay. Im not up with small block but the oil comes up the sides of shaft hold bolt on big block.
[Re: ozymaxwedge]
#2562747
10/12/18 01:47 AM
10/12/18 01:47 AM
Posts: 43,096 Bend,OR USA
CNC’d Stealth heads. Stock oiling. I did this to my Sons car this year and its working out great with Harlan Sharp rockers on Edelbrock heads. It a small block but the same idea could be used. I tapped the rocker shaft oiling hole on both heads and screwed a brass set screw in with a .060 hole in it. That way if I wanted more or less oil I could simply remove the rocker shaft and go bigger or smaller. I bought a bag a brass set screws off ebay. Im not up with small block but the oil comes up the sides of shaft hold bolt on big block. SB are the same except they don't oil both sides through the #4 cam journal
#2562827
10/12/18 11:44 AM
10/12/18 11:44 AM
Posts: 14,491 So. Burlington, Vt.
If you’ve done no modifications to the oil system that result in having full time top end oiling, then just bolt the rockers on and go.
#2562897
10/12/18 01:59 PM
10/12/18 01:59 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Thanks- I would leave the rockers alone and put in the correct cam, lifters and timing set. Fast68Plymouth spec'd an amazing cam for my build. Not knowing what you have now, increasing the ratio on your rocker arms may do little or nothing to take advantage of your set-up. It's all about the combination.
[Re: DrCharles]
#2562906
10/12/18 02:20 PM
10/12/18 02:20 PM
Posts: 1,959 Apollo, PA.
B1MAXX
Apollo, PA.
hmmm... my 451's cam came with the #4 journal grooved from the factory. It's quite small in width and depth as I remember.
Is there a simple way to add an oiling restrictor with the engine together? I don't want to have to pull the heads to drill and tap. Thanks. There is one way. If you look into the feeding pedestal typically you'll find that the top of the bolt hole is counter bored then the bolt thread starts. In the area of the counter-bore you will typically find the oil galley feed point. If you use thin wall tubing you can sleeve the counter bore area with a pre-drilled bushing made from the tubing.
[Re: B1MAXX]
#2562929
10/12/18 03:04 PM
10/12/18 03:04 PM
& you could stuff a piece of rag down below the angled feed hole to manage the debris then drill/tap for a setscrew drilled to what you want. that gives you the option to go larger/smaller in the future as (if) needed. Ahead of time I do this to all (5) vertical cam feeds from the mains down to the cam journals & drill each setscrew to 1/16" which is plenty for cam bearing/journal lubrication (1/8 on ones that feed the heads if going that route but on those (2) I do them all to 1/16 & feed the heads externally or from angled valley oil passage mods) so I can do all (5) to 1/16".
