Re: 727 shield
[Re: DoubleD]
#2561769
10/10/18 03:18 AM
10/10/18 03:18 AM
Posts: 20,166 Park Forest, IL
slantzilla
Park Forest, IL
the CSR shield solves both the transmission and Flywheel rule - actually has two SFI numbers on it - as with all safety products some minor adjustements needed - as in get the BFH out of the tool box! To make sure it hasn't been modified.
Re: 727 shield
[Re: dvw]
#2561882
10/10/18 12:33 PM
10/10/18 12:33 PM
Posts: 19,342 north of coder
moparx
doug, are you talking about the bolt together shield made of 1/4" aluminum plate ? Yes thanks doug. what do you use for a flexplate/converter shield ?
Re: 727 shield
[Re: cdwmotorsports]
#2561902
10/10/18 01:18 PM
10/10/18 01:18 PM
Posts: 9,824 MI, usa
dvw
MI, usa
It had TCI #940100. Pain in the but to get the trans out (my motor is slid back). I took it off. No one has even questioned it. That being said I'm going to make a small mod and reinstall it this winter. I've seen to many ring gears come off in the last year. Doug
Re: 727 shield
#2562427
10/11/18 01:21 PM
10/11/18 01:21 PM
hemi-itis
If you just use a blanket,your supposed to still have a flywheel shield. My heap has a shield with the HEMI set back 2 inches.
Re: 727 shield
[Re: OUTLAWSSAA]
#2563553
10/13/18 08:41 PM
10/13/18 08:41 PM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
That guy down there CSR is a piece of work. When I went to get mine recerted the second time, he gave me all kinds of grief. I had already sent it down there because I never dreamed of there being a problem. You basically couldn't tell this thing from new. He kept telling me he couldn't recert it because of this or that. None of it made sense. I kept on him for a legitimate reason. He finally came up with that after so many years the carbon fiber starts to lose its strength. After that he recerted it just to get rid of me. But I've talked to other people and he won't do a second recert. I not an expert so I couldn't tell if that was true or not about the carbon fiber losing its strength. Obviously it’s due to the extreme humidity where you live! ....of course if it were me we’d blame the dry excessive heat.
Re: 727 shield
#2563606
10/13/18 10:40 PM
10/13/18 10:40 PM
hemi-itis
C'mon fellas,,,,,it's all about the money How about belt certs?? 2 years is a joke,should be 5 years unless there are threads worn
Re: 727 shield
[Re: J_BODY]
#2563781
10/14/18 11:03 AM
10/14/18 11:03 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
It’s my take that they don’t sell any.... I’m assuming since I’ve been waiting since July for my 904 peice. I am hoping by the time mine gets to old to recert someone will have a SFI case for 727s and 904s....... not likely but hopes and dreams.
68 Barracuda Formula S 340
Re: 727 shield
#2563804
10/14/18 12:08 PM
10/14/18 12:08 PM
hemi-itis
Takes mucho dinaro to get a 727 built is SFI spec.But the one who does it will have a long battle making his money back!
Re: 727 shield
#2563828
10/14/18 01:17 PM
10/14/18 01:17 PM
Posts: 3,509 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
There will be a time when a transmission case can be 3D printed.
I guess that could be done now, but not in something that is strong enough and also light enough.
Re: 727 shield
[Re: dOc !]
#2564136
10/14/18 10:53 PM
10/14/18 10:53 PM
Posts: 991 Addison,IL
OUTLAWSSAA
Addison,IL
JUST TO GET RID OF YOU !! .. and this was after how long a period of time since new ? Was the CF de laminating at all ? Like I said in the post,it looked as good as new.
