Is this a bare Stealth head?
#2558060
10/03/18 12:59 AM
10/03/18 12:59 AM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
ebay 291722416620 $278 per head (bare) sounds pretty good, considering a Stealth is $500 and the valve springs/locks will be discarded, and I've read that the valve seats and guides may need work anyhow. They've sold a bunch of them. Thoughts?
Re: Is this a bare Stealth head?
[Re: DrCharles]
#2558174
10/03/18 11:39 AM
10/03/18 11:39 AM
Posts: 4,764 Holland MI Ottawa
2boltmain
Holland MI Ottawa
I believe all stealth heads are factory looking on their ends. Not machined flat and polished.
Keep old mopars alive.
[Re: RapidRobert]
#2559023
10/04/18 07:16 PM
10/04/18 07:16 PM
dogdays
If you spend time on your computer you can wade through all the engine parts being made in China and see that there are at least two companies making B heads. https://www.alibaba.com/showroom/440-cylinder-heads.htmlThe Stealth head was developed by 440Source and it is not available from anyone else. The other heads have the slab ends. I believe the more expensive heads are what we know as Sidewinder heads or ProMaxx. The less expensive C. Haray heads are sold under many names and can be bought all the way from rough castings to finished and assembled. These guys make everything! Cummins 6BT blocks, for example. R.
[Re: DrCharles]
#2559062
10/04/18 08:55 PM
10/04/18 08:55 PM
DrCharles
West Plains, MO
Interesting! Thanks for the link. Never heard of Chongqing Haray but I think you've identified the head I asked about.
It seems that no matter how expensive the head it still has to be checked 100% and probably some things repaired or resized. Even the high-dollar ones have been known to have water leaks, bad seats, etc.
So I'd just as soon buy bare heads cheap, and expect a shop to check/redo the valve seats & guides, do some mild porting, then put my valves, Comp springs and 10 degree locks on.
[Re: DrCharles]
#2563132
10/12/18 10:10 PM
10/12/18 10:10 PM
I’ve done a few sets of Speedmaster BB heads.
They work fine when properly prepped.
We put a set with a Stage 1 type job on a 446 with an rpm intake, qft ss830 carb, Mancini rockers, .540 solid cam, decent rods and flat top pistons.
[Re: DrCharles]
#2563296
10/13/18 11:09 AM
10/13/18 11:09 AM
4.375” bore, 28” test pressure, radius plate on intake, no flow tube on exhaust:
Lift———in/ex .100——70.4/59.6 .200—-145.6/108.5 .300—-211.2/146.4 .400—-255.0/178.1 .500—-280.5/203.0 .600—-287.9/219.6 .700—-284.9/228.6
