rear door on 08 ram wont open #2557749
10/02/18 04:35 PM
10/02/18 04:35 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
darn rear door wont open on the inside any thoughts on how to fixed it? i pull panel off linage still attach...
Re: rear door on 08 ram wont open [Re: BigTerry] #2557944
10/02/18 09:12 PM
10/02/18 09:12 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Dumb question time.... did you check to see if the child lock had been flipped on? work
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: rear door on 08 ram wont open [Re: I_bleed_MOPAR] #2559024
10/04/18 07:18 PM
10/04/18 07:18 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
Yep!
Re: rear door on 08 ram wont open [Re: BigTerry] #2559201
10/05/18 01:34 AM
10/05/18 01:34 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Originally Posted By BigTerry
Yep!
Yep, it was on or Yep, I checked?
confused
John
Re: rear door on 08 ram wont open [Re: BigTerry] #2561692
10/09/18 11:46 PM
10/09/18 11:46 PM
elyria, ohio
72gtx4speed Offline
72gtx4speed  Offline
elyria, ohio
The bottom latch has a tendency to rust up on those doors. Remove the door panel and start spraying a penetrant. Let it soak.
Good luck
Clem
when i grow up i want to be just like sunroofgtx, god please don't let me grow up.
Re: rear door on 08 ram wont open [Re: 72gtx4speed] #2562044
10/10/18 05:29 PM
10/10/18 05:29 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Good luck
Clem
If it was a 98-02 I would agree, but an 08 has the latch like the front doors.
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: rear door on 08 ram wont open [Re: Silver70] #2562550
10/11/18 06:52 PM
10/11/18 06:52 PM
elyria, ohio
72gtx4speed Offline
72gtx4speed  Offline
elyria, ohio
I just reread the post and realized i misread it the first time.
Good luck
Clem
Re: rear door on 08 ram wont open [Re: 72gtx4speed] #2562911
10/12/18 02:31 PM
10/12/18 02:31 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
so it could be rusted up ? i will spray it and see what happen.. thanks guys!
Re: rear door on 08 ram wont open [Re: 72gtx4speed] #2563808
10/14/18 12:14 PM
10/14/18 12:14 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
i try it the switch on and off no effect.. Im going to spray the assembly to see if that will work... Thanks guys!
Re: rear door on 08 ram wont open [Re: BigTerry] #2563867
10/14/18 02:34 PM
10/14/18 02:34 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
The rust thing was the 98-02 quad cab lower doors... I spray mine every 3 months or so, otherwise they get stuck. I highly doubt thats the issue on yours since the latch is mid door.
Pull the door panel and see if the rod is moving the arm on the mechanism. My 04 one of the rods popped off, no idea if that's common or not.
Re: rear door on 08 ram wont open [Re: Silver70] #2564016
10/14/18 07:32 PM
10/14/18 07:32 PM
Buford, GA
Buford, GA
You may need to R&R the latch assy. to inspect it and/or clean & lube it (or go ahead and replace it). If the inside handle linkage is still attached to latch, then it may be a problem with the child lock part of the latch. Taking the latch assy. out would make it easier to see and work on. twocents
Tim
'71 Charger 383/727
Re: rear door on 08 ram wont open [Re: BigTerry] #2564026
10/14/18 07:57 PM
10/14/18 07:57 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I had issues with all where they acted like they weren't closed and made the dome light come on and doors try to constantly lock while driving down the road... pretty much they are junk from the factory.
Re: rear door on 08 ram wont open [Re: Silver70] #2579909
11/18/18 06:08 PM
11/18/18 06:08 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
bump
