Re: Race gas octane
[Re: fowl play]
#2554561
09/25/18 04:30 PM
09/25/18 04:30 PM
Posts: 11,701 Portage,michigan
B3422W5
Portage,michigan
I ran a 13.1 to 1 W5 headed smallblock for years with 110 with zero issues. 32 degrees timing, 7400-7500 at the stripe. 95% of the time i was pumping the sunoco out of 55 gallon drums i would buy. Known good fuel.
Re: Race gas octane
[Re: fowl play]
#2554600
09/25/18 05:37 PM
09/25/18 05:37 PM
Posts: 34,831 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I run Sunoco 112 in mine , buy it by the drum ..
$500 buddy deal
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Race gas octane
[Re: fowl play]
#2554622
09/25/18 06:10 PM
09/25/18 06:10 PM
Posts: 11,408 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Sunoco was so lousy, I would not try to get away with running it on the edge. Maybe it's different now. Switching to VP made life easier.
Re: Race gas octane
[Re: fowl play]
#2555278
09/26/18 11:06 PM
09/26/18 11:06 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
For a quarter of the price try it on Avgas, see if it goes slower
1963 Plymouth Max Wedge 1971 Barracuda
Re: Race gas octane
[Re: fowl play]
#2555341
09/27/18 01:01 AM
09/27/18 01:01 AM
Posts: 52,972 Romeo MI
MR_P_BODY
It will mater more on your cam and where the center line is.. I was running 14.1:1 on E-85 with no issues at all
Re: Race gas octane
[Re: A/MP]
#2556630
09/30/18 01:59 PM
09/30/18 01:59 PM
Posts: 3,504 DFW
mr_340
DFW
I've run Sunoco with good results. Its not oxygenated like the VP and requires some attention. I'm experimenting with Klotz additive and 93 pump gas. At 12.5 no problems and it will be cheaper than Sunoco or VP. No bad plug coatings. It lasts indefinitely in the metal can. There may be a few HP with the race gas but I'm just running an index. http://apkgroup.com/msds/english/MSDS%20by%20Supplier/Winner%27s%20Circle%20(Klotz%20Synthetics)%20(WNC)/KL602(05-08-2017).pdf Hopefully it has iso-octane (reference fuel of 100 RON/MON) and not n-octane (-17 MON, -20 RON). https://en.wikipedia.org/wiki/Octane_rating
Floyd Lippencott IV
