Re: Shocks
[Re: madscientist]
#2555663
09/27/18 07:55 PM
09/27/18 07:55 PM
gregsdart
I can't think of a single reason to use SS springs and/or a pinion snubber. Ever. [/quote] While thier window of application has shrunk over the decades, to say "not ever" doesn't make sense to me. They still work WITHIN LIMITS, and combined with good enough shocks, the only change in performance would be the ET gains from a lighter wallet.
Re: Shocks
[Re: gregsdart]
#2555667
09/27/18 08:15 PM
09/27/18 08:15 PM
Posts: 9,824 MI, usa
dvw
MI, usa
While thier window of application has shrunk over the decades, to say "not ever" doesn't make sense to me. They still work WITHIN LIMITS, and combined with good enough shocks, the only change in performance would be the ET gains from a lighter wallet. [/quote] Well said. I've many times "used what I had". Sure if you are buying parts not on hand then the choice might be different. Doug
Re: Shocks
[Re: dvw]
#2555679
09/27/18 08:36 PM
09/27/18 08:36 PM
Thumperdart
State of confusion
We've achieved low 1.5x 60 foot at 123mph with Rancho adjustables. They need to be set tight. Try about 15psi. I would think at 120mph you should be able to go low,1.60 high 1.50s. Make sure the shackle doesn't limit travel. You may need to be moved forward or made longer. Better yet switch to sliders. Make sure the shock is long enough so it doesn't limit travel. If it does add an extention to the mount. Shock angle at this stage of the game isn't really a factor. Go to you tube; "64 Dodge shock tuning" https://www.youtube.com/watch?v=sjZDXBXRC9QDoug I went a 1.33 w/Rancho 90-10's ft and old 5-ways in the rear on #4...........
Re: Shocks
[Re: Mac's Hemi 64]
#2555810
09/28/18 01:52 AM
09/28/18 01:52 AM
hemi-itis
I wore out a set of rancho 5 ways then went to viking da shocks all the around with the more aggressive valving in the rear.Still and forever tuning.... with spit mono CTs.They have been consistent as I turn the power up.Adjustable boost is a wonderfull thing!
Re: Shocks
[Re: Mac's Hemi 64]
#2556054
09/28/18 05:26 PM
09/28/18 05:26 PM
Posts: 2,915 A shed in England
Tig
A shed in England
We had similar issues and went through Comp engineering shocks, Calvert's 5 ways - then 9 ways - AFCO Big gun D/A's and finally Menscer re-valved the AFCO's. Buying a good quality / rebuildable shock now, means you won't have to replace it when you step up (I really should listen to my own advice sometimes) Photo taken By Paul Green, Santa Pod UK Sept 6th 2018
Re: Shocks
[Re: AndyF]
#2556186
09/29/18 08:14 AM
09/29/18 08:14 AM
Tig
A shed in England
Ahh....OK my bad, but that's how I started
Re: Shocks
[Re: Tig]
#2556230
09/29/18 12:03 PM
09/29/18 12:03 PM
Posts: 3,159 Md.
carnut68
Md.
Cool pic. And no kids your ricer won't do that! That's what I tell my son about his Saabaru.
America First!
Re: Shocks
[Re: MR_P_BODY]
#2556625
09/30/18 01:48 PM
09/30/18 01:48 PM
BradH
If your front shocks are too short it will have a tendency to unload the rear.. you would like about 5" of travel on the fronts x 2; the amount of front suspension rise from the static ride height played a bigger part than I expected in getting my car to launch without unloading the rear tires after the hit.
